| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
pcv valve
here is a stupid question.. i am looking at my 2.3 4cyl and see my pcv valve just hanging i have looked and cant find the hole where in pushes in to? not sure how long this has been this way, but having a few probs with my car and wondering where it goes if you can help? there are no holes in the valve cover to put it.. one hose connects to the intake the other goes towards the firewall and around .. i just need to know where it plugs in
thanks |
Re: pcv valve
What type of fuel system you have? I'm guessing EFI
Re: pcv valve
yes i believe so the 2.3 with the 4 plugs on the exhaust side will be pulling the fuel rail and replacing injectors soon hoep to find it or knowwhere it goes by then thanks.. fi you can help it is the efi..
Re: pcv valve
Well, I just did a hands-on and followed the pcv hose to a place right under the intake system. The hose connects on a nipple about 2 inches in front of the oil filter.
Re: pcv valve
hey thanks i finally took a mirror and looked all over found where it goes.. actually a rubber hose coming from the front of the engine going back under the intake and angles up where some of the sensors are. couldnt see the hose before but with light and mirror i found it.. while there i replaced a few vacuum lines and stillacts like its not gettin fuel, until it warms up. cuts out, almost sounds like backfire throught the carb although it has fuel injection, back firing through the throttle body i guess.. any help here?
