Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-23-2006, 04:10 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
ignition moduel
alright i dont have any spark so i tested the coil to see if it was bad well no spark so i tested to see if the coil had power....no power.... a guy i know is a mechanic he told me that it might be the ignition moduel where is it at tho and how would i test it
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 08-23-2006, 04:24 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: ignition moduel
Try a different coil. There is no ignition module. It's the coilpack... that's all. Just replace it.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-23-2006, 04:31 PM
xavier3jr's Avatar
Re: ignition moduel
I've got the MSD coil on the way put there is no power running to the wires going tot he coil. I've already checked the fuse its good.
Old 08-23-2006, 04:32 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
Re: ignition moduel
could it possibly be the power transistor (ignition module)???
Old 08-23-2006, 04:37 PM
xavier3jr's Avatar
Re: ignition moduel
well wheres it at and how do i test it
Old 08-23-2006, 04:39 PM
my99cavy's Avatar
Re: ignition moduel
not sure where its located but I do know this is how you test it
  1. Connect the negative terminal of a 1.5V power source to terminal 5 of the power transistor connector.
Fig. 1: Testing the power transistor
  1. Check whether there is continuity between terminal 5 and terminal 8 when terminal 6 and the positive terminal are connected and disconnected.
Connect the negative probe of the tester to terminal 8 of the power transistor connector.
  1. With terminal 6 and the positive terminal connected, there should be continuity between terminal 5 and terminal 8 of the connector.
  2. With terminal 6 and the positive terminal disconnected, there should be no continuity between terminal 5 and terminal 8 of the connector.
  3. If the results of the test are not as specified above, replace the power transistor.
Old 08-23-2006, 04:48 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: ignition moduel
isnt that for the 4g63,,,i think it is......
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 08-23-2006, 05:00 PM
BOSTONjoe98gs
Re: ignition moduel
this should help you at least understand the ignition system in our cars.When the ignition switch is turned ON, battery voltage is applied to the ignition coil primary winding. As the crank angle sensor shaft rotates, ignition signals are transmitted from the multi port injection control unit to the power transistor. These signals activate the power transistor to cause ignition coil primary winding current to flow from the ignition coil negative terminal through the power transistor to ground or be interrupted, repeatedly. This action induces high voltage in the secondary winding of the ignition coil. From the ignition coil, the secondary winding current produced flows through the spark plug to ground, thus causing ignition in each cylinder.
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
Old 08-23-2006, 07:07 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: ignition moduel
Travis, there's a relay under the hood that has some control over the coil. It's called the ASD relay and I believe it's the second one from the left in the pack of 4. The pack is on the back right hand side, mounted on the firewall. You should be able to see it pretty easily. Don't just to breaking the relays though, they're definitely a pretty penny at the dealer and no aftermarket places carry them.
Edit: Also check your Crank Position Sensor. Mine was broken one time and I had no spark. I didn't check for power at the coil because it was brand new and figured it had to be something else. It's the sensor on the back of the block on the oil filter housing. Be careful when you remove it though if it's not already broken because they are pretty brittle.
95 Talon TSI AWD
97 Eclipse GST
Old 08-23-2006, 09:17 PM
xavier3jr's Avatar
Re: ignition moduel
ok guys i've narrowed it down i did some reading on 2gnt and i check the asd and i figured out that the coil only has power for like 2 second after u turn the switch on. so the coil has power everything is great. so this is what i narrowed it down to.
i put in NGK iridiums and they were "pre gapped" but they were at like .28 way low for a 420a because its suposed to be from .49-.53 so
A the plugs foueld out
B i blew my head gasket a while back and i warpeed some vaulves ( but it wasnt over heating at the time this happend)
C cam sensor
D crank angle sensors
OH an d i alsol tryed my ecu in a friends car to make sure it wasnt the ecu and there car started with it in it so ecu is great!
Old 08-24-2006, 01:24 AM
Re: ignition moduel
Plugs being fouled out or incorrectly gapped will have NOTHING to do with the coil having no power (or for only 2 seconds), nor will a blown headgasket. I'm still leaning towards the relay or crank sensor. I don't know if the CAS will shut down the coil or not, but I'll take a look on Mitchell and check. Were you doing any electrical work on it before it took a shit? (installing stereo, lights, etc)
EDIT: The CAS and CPS are in fact both interconnected with the coil. If both check out fine, I would check out the ASD relay, they have been known to go bad a few times before.
95 Talon TSI AWD
97 Eclipse GST
Old 08-24-2006, 12:22 PM
BOSTONjoe98gs
Re: ignition moduel
so did you figure it out yet travis? let us know
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
Old 08-25-2006, 12:25 AM
xavier3jr's Avatar
Re: ignition moduel
what is the CAS and CPS????
well i changed out my
cam sensor
crank sneor
plugs
wires
and i checked my
ASD reply
and my fuel relay
both of them are good
im leaning twards the coil went bad...my msd coil should be here anyday now hopefully tommrow
no garret i wasnt doing ANY eclitrical work the only thing i did before this happend was a tune up
new k&n air filter
fuel filter
spark plugs wires
the basic tune up nothing to do with anything elitrical
Old 08-25-2006, 12:29 AM
Re: ignition moduel
CAS is Cam Angle Sensor
CPS is Crank Position Sensor
95 Talon TSI AWD
97 Eclipse GST
Old 08-26-2006, 09:00 PM
xavier3jr's Avatar
Re: ignition moduel
need i say more.....
i've almost got the head off all i need is the 2 bolts for the intake manni but i couldnt find them working with a spot light. ill finish it up tommrow and let you guys know something.
