Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-23-2006, 01:03 PM
9rodeo9 9rodeo9 is offline
Strange Transmission issues- 99 rodeo
Hello-
I'm the original owner of 1999 Rodeo 3.2, auto trans, 2wd w/ 76k miles.
For about 3 weeks I've had a very rough thump when the tranny shifts (usually from 2nd to 3rd gear)- but only occasionally. After the 2nd incident I had a Transmission Drain and Fill done at my usual mechanic. No problems were found.
Also during one of the occasions, I tried to shift manually through the gears, but the tranny shifted through all gears while selector was in L ???!!!
I've since noticed that this tends to happen when I start the car with wipers left on from previous drive. Could be just a coincidence- but it's happend twice now.
ANy clues??? Hints??? (other than don't start with wipers on)
Thanks in advance
Old 08-23-2006, 01:26 PM
anthonyn anthonyn is offline
Re: Strange Transmission issues- 99 rodeo
Check out the FAQs, particularly the faulty transmission range sensor section:
http://isuzufaq.ibctech.ca/#faq59
Old 08-23-2006, 08:21 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Arrow Re: Strange Transmission issues- 99 rodeo
that FAQ# has a link to a real good pdf write-up with excellent photo's.
i'm also going to suggest this link to my posts at 4x4wire:
http://www.4x4wire.com/forums/showfl...5&o=93&fpart=1
"92 trooper AT harsh up-shifting 2nd to 3rd only"
i'm in the middle of figuring this out for my 1992 trooper, and i give alot of symptoms i'm experiencing that will probably confirm what's happening with you. . .
. . .plus it has a number of other good links that can help to confirm this diagnosis, and whether you want to try the clean and put back on option.
hth
edit.P.S.
for the life of me, i can't figure out what you're saying here. will you clarify? do you mean when you shifted manually to L and drove that the AT progressed thru the gears as if in Drive D ? Or?
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 08-24-2006, 09:41 AM
edit.P.S.
for the life of me, i can't figure out what you're saying here. will you clarify? do you mean when you shifted manually to L and drove that the AT progressed thru the gears as if in Drive D ? Or?[/quote]
Yes I mean that I manually put the selector in L, and as I drove- the transmission shifted as if it were in D. Crazy huh?
I think I will try the cleaning this weekend- wish me luck
Old 08-24-2006, 10:35 AM
Ramblin Fever Ramblin Fever is offline
It sounds like your range mode sensor needs a cleaning, as it doesn't know what gear it's in.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-24-2006, 11:59 AM
trooperbc's Avatar
well while i haven't read that one specifically as a symptom, it seems likely, considering the harsh 2-3 upshifting, that the range sensor/switch could be the culprit for this too.
luck.
bc
