Old 08-23-2006, 10:47 AM
deltableh deltableh is offline
Send a message via ICQ to deltableh Send a message via AIM to deltableh Send a message via MSN to deltableh Send a message via Yahoo to deltableh Send a message via Skype™ to deltableh
Different Color Primers affecting shade?
Does anybody know if using two different colors of primer (lets say, Testor's White Primer and Cobra Color's Black Magic) would affect the shade of bodycoat I'm putting on, which would be a Tamiya Bare Metal? I've got the DeLorean from the second Back To The Future, and certain parts are a darker silver than the main body, so two different shades is actually the intended result.
Old 08-23-2006, 10:54 AM
Nutsforcars's Avatar
Nutsforcars Nutsforcars is offline
Re: Different Color Primers affecting shade?
I would say that this is usually true. The difference in color depends on the color you paint over it. Red and white would show the biggest difference, but every light color will show a different shade.
I never used Tamiya metallics. It really depend on how opaque the paint is.
Old 08-23-2006, 11:14 AM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
I would give it a go over some test paint first to see how it would affect it. It is generally the case, but it depends on the paint, how much is applied and all that jazz. You may have to mix a darker shade of the paint you are spraying to get the desired effect.
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 08-23-2006, 11:24 AM
Normally I would mix darker, but it's Tamiya in a can, AS-12
Old 08-23-2006, 11:28 AM
white97ex's Avatar
hmm...then give it a test and see what happens. If you've got an airbrush, you could always spray it, then mask it off and hit it with a very thin mixture of tamiya smoke
Old 08-23-2006, 11:31 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Paint a DeLorean? Well, I guess you could do that, but why?
Got yourself a botle of this stuff-
-and a roll of aluminum foil, and cover it. If you want it to look like bare metal, cover it with bare metal. Paint it metallic, and it's going to look like it was painted metallic.
PHOTOBUCKET SUCKS
Old 08-23-2006, 11:53 AM
ZoomZoomMX-5's Avatar
Honestly I'd like to see the results; the wheel flares are probably going to cause BMF to get some wrinkles unless one is very skilled/very lucky. I've thought about using BMF, but before making the plunge I'd test it vs. the Alclad/metalizer route. A skilled artist can likely make either method look real.
As for the intial question, simply make a test piece that's 1/2 white, 1/2 black (primers) and see what the spray looks like. Some of those metal finish sprays are pretty opaque. TS sprays airbrush very nicely if you need to alter the shade.
My Fotki Album
Old 08-23-2006, 01:26 PM
Cold_Fire Cold_Fire is offline
Vendor
It depends a lot on the paint. For example, Dupont has 7 shades of primer (from white to black including 5 shades of gray) and each color has to be applied over an specific primer shade to get the exact match with the factory color.
It also depends in how we paint, we usually stop airbrushing when we think that it's completely covered, but that doesn't mean the coat of paint os opaque.
Old 08-23-2006, 02:10 PM
Jay! Jay! is offline
Horizontally Opposed
Reference pics?
You're not talking about the nose and tail pieces are you? Because those are actually gray plastic, not stainless steel.
If you found that actual stainless panels are different shades, consider a few things:
a. The stainless steel panels used on De Loreans have a "grain" to them, and will often appear to be different shades from different viewing angles.
b. BTTF was a movie, and they used a bunch of production De Loreans, plus several SFX models. You may have to consider if it's actually an intended trait of the fictional car, or just a continuity error that sneaked into the movie.
In my experience, the metallic paints I've used have excellent opaque coverage, and the underlying color has had very little effect on the finish. If I were you, I'd worry more about how to achieve that "grainy" look I mentioned above...
Hierarchy of Subaru:
(Click to see mine!)
Old 08-23-2006, 03:31 PM
Originally Posted by fubaz
Reference pics?
This is all I have to go on thus far.
Old 08-23-2006, 03:38 PM
MPWR's Avatar
Oh come on- do yourself an image search.
There are plenty of pics of Deloreans out there.
PHOTOBUCKET SUCKS
Old 08-23-2006, 03:47 PM
I know what a DeLorean looks like. I'm part of a driver's club. I love the thing. I'm just wondering how to get shades different.
Old 08-23-2006, 04:45 PM
But the only things called out by the instructions are the nose and tail, which are really gray plastic on the real car.
They shouldn't be a different shade from the body; they're a different color.
Or did I miss the point again?
