1980 Datsun 720 Pickup; idle problem
Just purchased at 1980 Datsun 720 Pickup, 2 liter. Engine was rebuilt, have aprox. 30,000 miles now. Has been sitting for approx. 2 years. We replaced plugs, plug wires, distributor cap and rotor. Cleaned the carb. including jets and they were totally gummed up. There was a short in the electrical system, the fusible link was burnt out but we replaced it. Everything seems to be working allright except it will not idle. It will start, but as long as you feed it gas it will run but once you let off the gas it will die. We have alreday tried adjusting the idle screw but didn't do a thing. Any suggestions would be appreciated.
| The Following User Says Thank You to xonforefunx For This Useful Post: | ||
Atozer (05-02-2011)
Re: 1980 Datsun 720 Pickup; idle problem
did you get rid of all of that old gas in the tank and put in fresh gas?
I suspect that the carb is gummed up. You may need to clean the carb and check any adjustments that can be made to the carb. Of course, you could just convert to a Weber DGV carb and gain so much over the stock Hitachi carb. There are also sidedraft Weber carb manifolds of the Nissan L4.
Anyway, as suggested above by dimefury the gas could be bad and you should drain out all the old gas. I think there should be a drain plug in the bottom of the gas tank, but you can also use a small electric fuel pump and come vinal hose. Stick the hose down the gas filler and connect the pump to 12v. That is how I do it. OK, after you drain out the gas, put in something like BG 44K or 2 or 3 bottles of any fuel system cleaner and then put some good gas (you do not need anything above regular low octane gas, premium would be a waste in the standard low compression L20B engine). NOW, run the car at idle (or in your case just keep it alive) for about 30 min or a little longer. Then stop the truck and leave it for about 18-24 hours. After that, see if it is any better. Even if it is not, drive it around for the day and it may start doing better. No mater if it is better or not, you should take it to high RPM on the highway and do a "Ferrari tune-up" for a few miles. Don't redline it, but keep the RPMs high. This will help to blow out carbon that has built up in the engine. Once you have done all of this, and if it is still not right, you may need to rebuild/replace the carb. I have some Datsun truck parts and Z-parts + other car stuff that I am selling off, so check it out: PARTS FOR SALE |
On the 1980 datsun there is a vacum line from the air breather to the intake if it is not hook up the truck will not idel.
check with avacumn gauge
well i have a 1983 Datsun 720d pickup and it run well, it idles a little bit under 1000 rpm but if it is reved and is returning to idle it goes way below ans almost stalls. can someone help me?
Esky Honey Bee FP V2 |
