clutch bleed problems with 94 Ranger
I have a 1994 Ford Ranger/Manual Tranny. A few weeks ago i noticed it was getting hard to shift and eventually became very hard. I discovered that my clutch fluid reservior was empty. When i filled it up it became much easier to shift but the clutch was still a little mushy. so upon further studying online decided that air must've gotten into my clutch line when it was empty and it needed to be bled.
I must've not been thinking when i started bleeding because i loosened the bleed screw and then pumped the clutch in and out. obviously all this was doing was pumping air into my line. once i realized my mistake i gave it a day and then tried bleeding correctly according to Auto Zone's guide here... AutoZone.com | Repair Info | Ford Ranger/Explorer/Mountaineer 1991-1999 | Drive Train immediately when i loosen the bleed screw clear clutch fluid comes out, not bubbly or anything. i can tighten it and repeat it forever without any effect. if i let it drain for just a second or two it stops and nothing comes out. is this where the air bubble is? i can let it set open for a while and still nothing bleeds from it. and my clutch is complete mush. is bleeding correctly going to fix this problem? like i said, before i pumped air into my line, it worked fairly well, so i don't know what else it could be, i just can't figure our this bleeding thing. do you guys have any suggestions or more questions. please let me know, i'd like to have a functioning truck again, thanks! |
Re: clutch bleed problems with 94 Ranger
how fast did your leak take to be noticed when you would fill? If mine is a leak it isn't noticable after 3 weeks so far. My father is coming today and we'll try again, if it doesn't work i may look into the line itself. |
my neighbor is a ford mechanic and checked it out. he said since there is absolutely no pressure being built up from pumping the clutch (when you bleed it there isn't any type of strong flow at all, just a slow trickle)... than he thought the master cylinder must have gone or have a air leak somewhere not allowing pressure to build in the line. The slave looks good and is no trace of leak there, so it probably is the master.
does that sound right to everyone else? i guess there's no way of really knowing other than buying the part and replacing it. i'd rather not spend that money and then find out it's something else though if it is though, what's your thoughts? |
