Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 08-23-2006, 09:50 AM
S13Driftfiend's Avatar
S13Driftfiend S13Driftfiend is offline
Send a message via AIM to S13Driftfiend
shaved antenna
have any of you guys gotten away with just fiberglassing the hole, or is does it absolutely have to be welded?
SHIFT_S i d e w a y s
Originally Posted by slideways...
you fail at life. go back into your mom's uterus and de-evolve into the nut stain i left on her sheets.
Old 08-23-2006, 09:55 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: shaved antenna
bondo is what i used on my old hatch. i did a shitty job because it was my first time using bondo and it still lasted like 2 years.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 08-23-2006, 11:52 AM
MetalHeadZaid's Avatar
MetalHeadZaid MetalHeadZaid is offline
Re: shaved antenna
im still deciding if i should bondo my spoiler holes or just eat the shit and get them welded...i dont want to have to use bondo more then once
S13
Silvia Q's - R.I.P.
R32 GTST Type M Sedan - Sold
R32 GTST Type M Coupe - Sold
S14 Silvia K's - daily
R32 GTS4 - BETTER BE READY!!!
Old 08-23-2006, 12:05 PM
Re: shaved antenna
i think i might just bondo/ fiberglass it... slideways did you bondo from the inside too or just the outside... its a bitch to get to on the inside if i remember isnt it..?
Old 08-23-2006, 12:06 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Re: shaved antenna
i use the reliable ever so useful quick fix DUCT TAPE, yeah BAYBE
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 08-23-2006, 12:11 PM
Re: shaved antenna
outside. all you have to do is put some of that hard mesh backing on the inside and bondo over it, then sand it down flush with the body, fine sand it, primer it a couple coats, then paint over. it is a bitch to get to, but not impossible. i also did this with my spoiler holes and my rear wiper hole.
p.s. the main reason it only lasted 2 years is because i didnt think to use that mesh stuff and used masking tape as a backing plate. dont do this.
Old 08-23-2006, 02:22 PM
Re: shaved antenna
hahaha yea ill prob end up doing the mesh.. and fortuneatly for me my hatch didnt have a rear wiper OR wing
Old 08-23-2006, 07:22 PM
Chuki_breath Chuki_breath is offline
Re: shaved antenna
im welding mine along with the sidemarker lights, luckily my quarter panel is off the car lol. Bondo will crack over time anyways with out a solid bonding surface. If anything use the mesh, then fiberglass over it, then bondo over that. Make sure you grind down to bare metal around the area being applied too.
mesh,fiberglass, sand, bondo, sand, prime, sand, paint, clear, sand. Wear gloves with the fiberglass, it will get tingly and start to burn on bare skin after a while. You dont absolutely have to just a warning though.
1993 base model 240sx coupe......to much to list. Just take a look at the link, 10 pages of goods.
http://community.webshots.com/user/nismosilvia240
Old 08-23-2006, 09:24 PM
Re: shaved antenna
yea i was thinking about mig'ing it, but i have no wire on the spool lol so im just going to glass it. and i know all about the burning and tingling sensation... and im talking about fiberglass work not fooling around with chlamydia infected girls, in case some of you were confused with the "tingling and burning sensation"
thanks for the tips i was planning on glassing in the first place but just wanted to see what you guys did first
EDIt: WASTEd.
Old 08-23-2006, 09:50 PM
zacremacle's Avatar
zacremacle zacremacle is offline
Re: shaved antenna
Just glue it that is how I have shave everything i have done. Just make sure you get the right glue. go to an auto body supply store and pick up a tube of metal adhesive that is how a lot of the people do it now it is done correctly. that way you have no warping of the metal from the heat of welding.
Old 08-24-2006, 07:08 AM
Re: shaved antenna
im just gonna fiberglass it... but thanks for the tip
Old 08-24-2006, 09:21 AM
Firewind's Avatar
Firewind Firewind is offline
Re: shaved antenna
Fiberglass might be the best way to go. It may crack, though being such a small area it may not for a long time.
The problem with bondo is, yes it cracks.
The problem with welding on the body of your car, is it can cause it to rust quicker in that area. Though this is less like to be much of an issue where the antenna is.
That's just my 2 cents. Myself, I'd go with fiberglassing.
Old 08-24-2006, 08:52 PM
Re: shaved antenna
It will not rust, its covered by bondo/primer/paint/clear coat like the rest of your metal car. Now body panels can rust from the under side out. Which is 99% of the time what happens from not being covered properly (splash shields etc.) But the antenna area is in the trunk, so no water should hit it lol.
Metal adhesive works great too. Thats the way body shops repair bedsides/quarter panels/roof panels(or any welded on panel) 99% of the time these days. It saves alot of time and makes the shop money becuase your paying a flat rate of hours and it takes half the time of the quote. Basically you grind the spot welds, remove damaged panel. Then get the metal adhesive(there's different types with longer/shorter dry times). Put a solid bead (its just like caulking) on the area that would generally be spot welded then get 1,000,000,000 vice-grips and clamp it down TIGHT in the right position of course and let it sit over night. Thats it in a nutshell. I think i can change a bedside (truck bed side) in my sleep. They pay 8-10 hours and only take like 3-4 to do lol. Those make you a great deal of money. Yes if you glue your hand to something your royaly screwed.
Old 08-25-2006, 03:11 AM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
Re: shaved antenna
when my sunroof leaked i wasnt sure if it was the inner or outer shell seal so i just duct tapped my whole roof. lol. Duct tape fixes everything. I also got many JDM looks at local meets
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 08-25-2006, 08:18 AM
Re: shaved antenna
yea luckily my sunroof leaked for one day, i tightened the screws in the flip up handle and its been fine ever since.. i do have that famous leak in my hatch tho.. theres a write-up on ka-t.org to fix it i just havent gotten around to playing with it yet
