Old 08-23-2006, 09:10 AM
bochnak bochnak is offline
clearing codes for 00' windstar 3.8..mass air and egr
My old man had the codes read by Autozone indicating a mass air flow sensor and egr valve. After I replace these components, how do I clear the codes or get the check engine light to turn off? Disconnect battery???
Any tips or comments on the upcoming repairs?
Thanks in advance,
Matt
00' windstar 3.8L
Old 08-23-2006, 09:28 AM
busboy4 busboy4 is offline
Re: clearing codes for 00' windstar 3.8..mass air and egr
Hi,
You might post the codes if you have them so we can share info if we have dealt with the same codes. After the repairs the light may go out after a certain number of drive cycles (don't know exactly how many, 5 I think), or, you can go back to autozone, and the scanner that reads them can also clear them.
Old 08-23-2006, 09:35 AM
Doug360 Doug360 is offline
Disconnecting the battery will clear the codes. After you disconnect, step on the brake just to make sure the vehicle's power is totally drained.
Old 08-23-2006, 09:50 AM
Originally Posted by busboy4
Hi,
Thanks for the quick response. I don't have the codes on me, sorry. I will try the cycles, if not, I'll go back to Autozone to have them cleared.
Thanks,
Matt
Old 08-23-2006, 09:51 AM
Thanks. It looks like I might have to remove the battery anyway to gain better access to the EGR valve.
-Matt
Old 08-23-2006, 10:09 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Before you clear the codes, at least try to get them and post them here so we may direct you on fixing the initial problem.
Old 08-23-2006, 11:00 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
If you can get away with NOT dis-connecting the battery, don't. The PCM will have to re-learn everything, plus you gotta re-do the radio presets..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-30-2006, 10:48 AM
I have replaced the mass air sensor and egr valve. Still getting a code "insufficient flow to egr."
I tried cleaning the block passage best as possible. Should I go back in there with a wire pipe cleaning brush? Any tips?
Thanks,
Matt
Old 08-30-2006, 11:03 AM
Hi Matt
Once again, it would be nice to know the codes you are getting. With that said, last time I dealt with EGR insufficient flow, I changed the DPFE sensor to deal with it as directed by others on the board. It worked. I would guess the code is P0401.
Old 08-30-2006, 01:06 PM
I agree, it's either the DPFE EGR valve-controller, or the EGR pipe from the valve to the exhaust pipe could be clogged. If either of the hoses going to the DPFE sensor were clogged, I would think it could cause a code. The part you'll mostly likely have to buy usually isn't cheap, either. It's called a Delta Pressure Feedback Exhaust Gas Sensor, It's controls the vacuum signal to the EGR valve. DPFE for short.....
Old 08-30-2006, 10:32 PM
wiswind wiswind is offline
EGR valve RARELY fails on the windstar.
Insufficient flow, first thing would be the DPFE, as advised, when you change it......check the flexible hoses that go to it......to make sure that they are in good contition, no cracked, clogged, etc.
The other thing to check is the vaccum line that goes from the top of the EGR valve, to the EGR vaccum control solenoid, and the vaccum line from the EGR vaccum control solenoid to the vaccum source.
Another thing that can cause the insufficient EGR flow is clogged EGR ports in the lower intake manifold. You have to remove the upper intake manifold to get to them.....and the crud will be right at the end of each port (1 for each cylinder).
The DPFE will be much easier to replace than the EGR valve was.
And the Vaccum lines, while you have to be patient and thorough.....is easier yet to check.....and the cheapest.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
