Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-23-2006, 07:52 AM
Mira_cz's Avatar
Mira_cz Mira_cz is offline
Send a message via ICQ to Mira_cz
ABS problem
Hi, I have 91 caprice classic. Today I drove home and suddenly ABS control lamp lighted up. I tried brake hard, car went to slip. What is the first thing I have to check? Some sensor? Thank you.
Old 08-23-2006, 11:46 AM
GranniesCaprice GranniesCaprice is offline
Re: ABS problem
Well first thing you have to do is get it scanned, and see what DTC's are setting. This will lead you in the right direction, whether its a relay, sensor, module, wiring, or pump problem. Without the DTC's you could look all day and not find the problem.
91 Caprice 305 700R4 2.56 225/70R15
Old 08-27-2006, 05:53 AM
Mira_cz's Avatar
Re: ABS problem
Unfortunately, no diagnostic trouble codes, connected with ABS. 44, 45, 46 and 54.
43 Electronic Spark Control (ESC) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
54 Fuel Pump Circuit (Low Voltage)
I found out brake pads and brake shoes are not i perfect condition, could mailfunctioning ABS indicate this?
Old 08-27-2006, 09:50 AM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
Re: ABS problem
there could be brake dust build up on the sensor/teeth on the rotor for the abs
when you do the front pads take the rotor off and look at the teeth on the inside to see if there all still there, and that sensor isnt all dirty.
might help.
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
