Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-23-2006, 04:30 AM
L-Spec's Avatar
L-Spec L-Spec is offline
Send a message via MSN to L-Spec
Clutch Options
Haha, I read the other thread titled "which clutch", but I felt that this didn't exactly fit in that other thread (and I didn't want to jack his thread), so I have a quick question for you guys and I hope you guys know your drivetrain!
I have a worn clutch and I'm in the market for a new disc. I have my eyes set on a race disc, but I want to keep cost down as much as possible. What I want to know, is: Would I be able to use the stock pressure plate with a race clutch disc or would it be too much for the stock pressure plate? Would the race disc affect the durability/performance of the stock pressure plate at all? Should I get a race ready pressure plate to compliment the race disc? I'm all for dishing out a bit of extra cash to make things work smoothly, but I don't want to spend money on something I don't need. Thanks..
1992 Ẽfini RX-7 FD3S
Old 08-23-2006, 10:23 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Clutch Options
Yeah, I would just do both. I would also suggest a sprung 6 or 4 puck 2600. I dont think they are too expensive. I just drove my buddy's del sol with a sprung 3 puck stage 2 exedy clutch and uber lightweight flywheel. That shit was bananas. Sprung pucked clutches and lightweight flywheels are the shit. This faggot ass grand am wanted to race. Yeah, that was funny. He was a stock V6 (not sure if it was a grand am, but it was some domestic 4dr V6) and Eric's del sol has I/H/E and the clutch and 7.5lb flywheel. I didnt even launch and at the end of 3rd gear I had easily a bus length and a half on him. Anyway, back on topic, I would suggest a sprung pucked clutch.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-23-2006, 03:44 PM
L-Spec's Avatar
Re: Clutch Options
7.5 pound flywheel? Holy shiiiit. I also heard about durability issues regarding the exedy clutches...
Haha, so it would be fine if I used a race clutch on the stock pressure plate without any below OEM performance issues and durability, correct?
I'll definitely replace the entire clutch assembly, but for now, I just want to get the clutch disc. I'm just trying to get the most needed parts in first just so I can get my car back on the road -- so that kind of explains why I'm trying to cut costs down as much as possible and I'm sure many people understand
Old 08-23-2006, 06:14 PM
Thor06's Avatar
Jizzed In My Pants
Re: Clutch Options
I wouldnt do that. I would just save up and get the whole thing. If you just have the clutch disk, I would imagine that the disk would get worn to the pp, then a new pp would cause it to not work as well as it should. If you were to use a different disk with the old pp, I would just get another used one or a autozone or something.
Old 08-24-2006, 01:46 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Clutch Options
I would just replace the whole assembly....usually when you kill a disc the pressure plate is done too....and even just regular use can warp your pressure plate enough to where you probably wouldnt want to keep it around....
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 08-25-2006, 08:18 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Clutch Options
DSM drivetrains and puck clutch discs do not get along well, even sprung. But sprung is better than solid. Of course then you give up one of the only advantages puck clutches really have in my opinion; low weight. PEople often do lower the pressure plate pressure significantly when using pucked clutches, like a 2100 instead of a 2600. A stock might be too light, but if there was a reason to use one, it should be a new one, not the used one you already have in there.
The vast majority of people on this forum will do well going to an ACT 2600. I don't recomend even bothering with a 2100. You can also look into SBR and other comapanies equivelant of the 2600. The main point being a full face organic disc. At high HP levels organic discs can be tricky, but the only worthwhile alternative IMO is a twin disc clutch from PTT, Tiliton, Quartermaster, etc, and those are much more expensive and come with thier own list of problems to deal with
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
