Old 08-23-2006, 01:22 AM
thedeadcivic's Avatar
thedeadcivic thedeadcivic is offline
Cool mmmm SOHC :P
anyone got any suggestions for a new performance exhaust for a D16A6 1990 Civic Si ? its probably not really worth it, but what else am i gonna spend my money on? acctually... if anyones got any better ideas where to start first, let me know. the only thing ive put on it is a cold air intake.
*stuck with sohc
Old 08-23-2006, 07:40 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: mmmm SOHC :P
dc header, hi-flow cat, resonator, 2-2.25" alumnized pipe custom bent to dynamax muffler...
After you do this, and you like what you've got and need to change the timing belt and/or waterpump, get a lightweight pulley set. If you need to replace the clutch install an exedy one with a lightweight flywheel.
IMO, the sohc 1.6 si engine with mpfi has much more potential than the dpfi 1.5 engine without ever having to switch heads or add vtec...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 08-23-2006, 01:21 PM
DirtyD777's Avatar
DirtyD777 DirtyD777 is offline
Send a message via MSN to DirtyD777
Re: mmmm SOHC :P
stuck w/ sohc????
the a6 is a awesome little motor imo, many options for making it fast.
Old 08-24-2006, 01:11 AM
Re: mmmm SOHC :P
should i stick to a dc header or should i buy any kind of performance header? hmmmm, the dynomax exhaust is probably my next step even though its not the most important. my tailpipe is like... an inch and a half in diametre and it looks pathetic...
also, the reason i was looking down on my sohc is because everyone ive talked to never had anything good to say about them.
if you got any cheap (in price, not quality) parts to suggest that would be awsome because my income is not as good as i would like it to be :P
Old 08-24-2006, 03:45 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: mmmm SOHC :P
hey there is a lot of potential out of single cams. don't let everyone's opinion influence yours. it's YOUR car, not their's. my friends single cam can beat all the stock b16's in town.
-tony-
2000 honda s2000
Old 08-24-2006, 11:21 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: mmmm SOHC :P
sure there's a lot of potential with single cam...but not NA
best bet before you start doing anything is to have a plan...if you want to eventuall do a motor swap...then save your $$$ for that instead of getting an exhaust setup that will net you only 10bhp...
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 08-24-2006, 12:22 PM
Re: mmmm SOHC :P
I disagree. My car was plenty fast when it was all motor high compression. And that was without the bigger diameter exhaust, lightweight flywheel and CAI.
I agree about the having a plan and doing a swap. If you're going to swap, then don't bother because the header won't bolt up to the new motor.
Don't knock an all motor single cam. Having a dohc engine isn't exactly heaven on earth.
2010 Honda CR-V EX
Old 08-25-2006, 01:41 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: mmmm SOHC :P
you got to admit b series will always over power d series in the long run. what you did was smart with a d series but not so smart because you could have made almost twice the power on a n/a b series. but i have to admit i would love to spank a v8 and then a b series all in one night with a single cam turbo.
Old 08-25-2006, 07:53 AM
Re: mmmm SOHC :P
The only way this is true is if both d and b had the same mods. There are tons of sohc engines spanking dohc engines and you don't need a turbo to do it.
Think about it this way... I bought my car for 2,500 with an engine that had 11.0:1 cr pistons, metal headgasket, aem cam gear, crane cam, unorthodox pulleys, intake, exhaust, header, ignition and a lot of rice. Other than the rice, the car was a ton of fun and I'll never forget the look on the dude's face with the b16ed crx with the custom body kit molded on when he tried to race me and I pretty much walked him up to 100mph. This was with the car untuned... The only difference in my set up is the stock compression pistons and I have a better exhaust, cai, clutch and flywheel. So the car is almost the same but more reliable. Now, are you still going to tell me that I could've spent the same amount of money for a swapped crx and got more power? I don't think so...
2010 Honda CR-V EX
Old 08-25-2006, 09:08 AM
BLU CIVIC's Avatar
調整器
Re: mmmm SOHC :P
HOLD ON...before we get anymore responses...i'd like to direct everyone to here
http://www.automotiveforums.com/vbul...archid=1649155
i knew i remember'd this topic from somewhere
The name's Adrian
2011 CR-Z - Stock
Old 08-25-2006, 10:45 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: mmmm SOHC :P
ive got a bunch of parts for the a6 lying around look in the classifieds. got a dc sports adjustable cam gear lyin around that hasnt been used. im glad to see someone workin on sohc just because it is possible to make them worthy just takes time and planning like turtle said.
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 08-25-2006, 02:32 PM
yeah i dont think imma do a swap, im probably going to buy a new car in the next year or two soooo for now, i just want it to be a bit more fun.
