over heating
i have a '97 venture that keeps on overheating.
i changed the t'stat,changed both fan motors,removed the radiator took it to get cleaned. they took it apart and cleaned it. still kept on over heating .so i removed the t'stat.still overheating. what can it be? help any1 |
Re: over heating
The water pump impeller could be erroded away. Not circulating any coolant.
Re: over heating
At any time you opened the cooling system,(i.e. removing thermostat, or removing radiator,) did you ever bleed any air out of the system once you put it all back together? I've seen 'pockets' of air cause overheating problems which went away once they were removed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Re: over heating
Re: over heating
Re: over heating
