Go Back   Automotive Forums Car Chat > Lincoln > General Discussion
Old 08-22-2006, 06:32 PM
soicy423 soicy423 is offline
1987 mark 7 lcs wiring color codes
i need wiring color codes for a 1987 lincoln mark 7 lsc.....i'm tryin to hook up a cd play beut i don't know which wires go to what.......the factory wire connectors are cut off
the wire colors are
red
black with a white stripe
yellow with ablack stripe
dark green
white with a red stripe
lime green
lime green witha yellow stripe
pink with a lime green stripe
pink with a thick blue stripe
pink with a skinny blue stripe
orange with a blue stripe
2 blue with a red stripe
Old 06-08-2008, 05:56 PM
Adam012985 Adam012985 is offline
Re: 1987 mark 7 lcs wiring color codes
Dude, just use a 12 volt light tester and find your constant + feed, acc on + feed, a ground, then hook up the power for the cd player, then use a set of speaker wires from the cd player to find your speaker wires, but if your mark VII is anything like mine you will need to run new speaker wires due to the factory premium sound setup [email protected]
