Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 08-22-2006, 05:59 PM
tocatodd tocatodd is offline
low beams not working high beams do
Has anybody else had this problem? My relay and fuses are good, but I can't figure out why the low beams will not work.
Todd
Old 08-22-2006, 06:49 PM
Flash75 Flash75 is offline
AF - Advisor
Re: low beams not working high beams do
A shop manual for 2003 lists possible causes as.
1. Head fuse (LO LH, LO RH).
2. Headlight dimmer switch.
3. Headlight dimmer relay.
4. Headlight bulb.
5. Wire harness.
You need a shop manual to troubleshoot each possible cause, fuses and the relay are easy. I had a link to a 2003 shop manual but it doesn't show up.
Clifton
