Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 08-22-2006, 03:50 PM
musclecarfan6's Avatar
musclecarfan6 musclecarfan6 is offline
stabilizer link
I need to know how to take off a stabilizer link or sway bar whatever it's called. I wrecked my car and I am currentlly fixing it. Please help.
Old 08-23-2006, 09:21 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: stabilizer link
The stabilizer link is basically a long bolt with rubber bushings, a spacer and some washers on it. If they are rusted, just cut the bolt and replace with new (they're only $4-$5 each). To remove the bar itself, there are two rubber mounts that hold the bar to the frame. Jack the car up and support it on jack stands. Remove the stabilizer links first, then reomve the two bolts that attach the frame mounts to the car and drop the bar out. Depending on how the bar is routed through the frame, you may have to remove the tires for clearance to fish the old bar through and out.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-24-2006, 05:59 AM
Re: stabilizer link
thanks. that helps
95 Plymouth Neon 2Door 2.0L SOHC
89 Buick Century Custom 3.3L
____________________________
What to see pics of my cars. Go
to www.cardomain.com and look
for musclecarfan6. Rate or leave
comments if you want.
