Can someone tell me how to wire up my horn again? I got a pic.
Here's where I'm at, I'm pretty sure the black wire at the bottom is for my buttons but I can't seem to find where it plugs into, is it behind the yellow airbag ring?
Re: Can someone tell me how to wire up my horn again? I got a pic.
Meh... use your finger. ok the axle shaft.. see the larger hole to the top left of it?... mm kay...its almost touching the axle shaft. That hole.. u put the spring in there and i beleive u twist it to lock in. just push it in and try to get it to stay in. Then in the same spot on opposite side is where the black wire clip goes.. i think u just close it and shove it in the hole and it should stay in there..make sure the ground is connected first, cuz if it gets a surge of power but no where to ground.. it might well do what it does.... HONK!
Please don't PM me with your J-body Issues. Post appropriately in the forums, and I will toss my opinion in your thread if I have anything to help. - Thanks! 2006 Chevrolet Trailblazer 2010 Glastron GT 205XL |
If I'm installing an aftermarket wheel am I able to take the axle shaft out or do I need that to turn the wheel? Because I have a quick release hub but there's no hole to fit the shaft.
I'm not too familar with the quick release hubs, but on the momo one designed for GM.. you just remove the nut and put the new hub over that sucker.
I know but I already bought a quick release, do you know if you're able to remove the shaft or do you need that to turn the wheel?
Momo hub adaptor for GM.. this is the best pic i can get ya bro...
