Old 08-22-2006, 07:44 AM
dcrader dcrader is offline
Question No brake or steering power
1996 Astro Cargo brake and steering power failed changed the HYDRO-BOOST , that did not change anything.
Old 08-22-2006, 10:30 AM
Blue Bowtie's Avatar
Registered Offender
Re: No brake or steering power
Is the pump running? Have adequate fluid?
Is the pump is moving oil? (You can install a clear poly hose on the return line to monitor oil flow.)
does it help to move the steering wheel to a lock/end?
Old 08-22-2006, 01:43 PM
Supergumby's Avatar
Supergumby Supergumby is offline
Take the belt off, and see if the power steering pump pulley will pull out (forward). These shafts fracture a lot. It won't leak or make noise, the shaft is just not connected to the vane wheel anymore, and it no pumpy fluid.
