Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-22-2006, 01:32 AM
ryanvv355 ryanvv355 is offline
1992 Accord brake issue
I'm trying to peddle a 92 LX Accord and am having a brake issue, When i bought it the front inboard driver side brake pad was completley worn, no friction material left. The rest of the pads where ok. I replaced the rotors, pads and driver side caliper and now the brakes drag on the driver side, when I turn right the drag goes away and left the nosie stays. any thoughts??
Old 08-22-2006, 11:36 AM
somick's Avatar
somick somick is offline
Re: 1992 Accord brake issue
It sounds like you have lubricating issues.
Two rods on which the caliper slides when you press brake pedal should be lubricated.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 08-24-2006, 02:08 PM
It was the little metal pad slides, the old ones where nasty and bent, put new ones in and no noises. Im happy
