Old 08-22-2006, 12:18 AM
chadis's Avatar
chadis chadis is offline
door ajustments
hey i recently bought a 1987 camaro and the doors are set to low it seems they rattle and i was wondering how to adjust them..any info would be nice thanks
Old 08-22-2006, 09:18 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: door ajustments
What you probably need is a new set of door pins.
Old 08-22-2006, 09:20 AM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
Re: door ajustments
I'm not exactly sure what your saying about adjusting but you might need to replace the door pins. When you open up your door try to pull up on it, if you can move it than you need new door pin(s) or hinge, but probably just the pin bottom pin. Another sign is if you see scrape marks where the bottom of the door is touching the car.
Edit- wright beat me to it
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 08-22-2006, 12:43 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: door ajustments
only adjustments that can be done is with the latch and striker. door sage is pretty common on 3rd gens cause the doors are so heavy and replacing the pins and bushings is the only whay to correct the problem. the other posibility is a worn out hinge
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 08-22-2006, 04:11 PM
chadis's Avatar
Thumbs up Re: door ajustments
thats wht i thought new pins thanx
Old 08-22-2006, 06:11 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: door ajustments
mine is scraping at the bottom also. so i bought pins and bushing kit and took it to my auto body buddy, and he said the pins are not that bad at all, he sad if i feel under the door, it is the trim peace starting to rub and to sand that down a little. because when i lift on my door, it does not come up much.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 08-23-2006, 09:25 AM
wrightz28's Avatar
Re: door ajustments
Any flaw in a pin on a door that weighs as much as these do is problem.
