Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-22-2006, 12:00 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
'91 9C1 rebuild.....
So I call Summit today to order a master rebuild kit with forged pistons and stage II summit rods and they tell me they don't have a kit for my boat. They mentioned something about a .167" shallow oil groove. Why can't I order any pistons for this thing!?!?
'91 B-body LO5 5.7, BTW
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-22-2006, 09:48 AM
capriceowns capriceowns is offline
Re: '91 9C1 rebuild.....
Have you tried going to sepreate compaines and ordering indiviudal parts and making your own master rebuild?
with so many 350's out there I would have figured they would have the parts flowing out their ass.
Old 08-22-2006, 12:08 PM
I think the Summit dude I talked to was a moron, at least I hope he's not right. I thought about buying seperate pieces, but It'll cost so much it wouldn't be feasable..
Old 08-22-2006, 05:52 PM
HLandin's Avatar
HLandin HLandin is offline
I know that Rock Auto allows you to buy a complete long block or the individual parts (such as pistons), but I don't know if that is what your looking for. Just check around, and I'm sure you will.
Old 08-22-2006, 08:51 PM
Well, called Summit back, got an explanation.. The Oil ring groove is shallower on the 9C1 350 than any other 350. There is a kit for pickups 87-92 with the shallow groove, but it will not work with the police engine, and they aren't going to make a kit for the car..Dammit! So I call GM, they say sorry no parts are being made anymore...I didn't think I'd ever see the day when you couldn't rebuild a small block 350. GM and Summit and Jegs suggested getting custom pistons made, YEAH RIGHT! So anyone need a rock solid 700R4 and 8.5" LSD rear-end before I call the salvage yard n tell 'em to come get this worthless pile of bowtie...May she rest in peace.
Old 08-23-2006, 08:33 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
I think I missed something; the new rings and pistons won't fit your cylinder bore because the current pistons have a shallow oil ring? Shouldn't make any difference in my mind. BTW, where can the car be picked up? :-)
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 08-23-2006, 10:11 PM
I'm not exactly sure why it won't work, but summit said they tried it before and it bit them in the arse. I'm still not sure why if I was using new pistons, but....The car can be got in North East Arkansas. It's a shame since I just put $1400 in parts alone into the transmission, and the rearend has a 3 year old factory GM ring and pinion in it. I did all the bearings and LSD when I installed 'em...
Old 08-23-2006, 10:23 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Why not just run stock pistons in it then? Or go with a nice set of Keith Black hypereutectics - those work well - at least in my engine with 262k on them they do.
There's no way that a stock piston WON'T fit that engine - the block is the same regardless of what it's used in (with the exception of #bolts on main caps).
However, if you really don't want the hassle, I'll take the transmission.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-23-2006, 10:31 PM
Well, $600-$700 was all I was going to spend on it, and since my dream got shot to hell, I started daydreaming about my Monte again..so my funds are "shifting". If ya want the trans, ya gotta pull it. I've helped you already by killing the millions of super-hybrid yellow jacket/red wasps. Never seen a red wasp with a yellow belly. Don't let the color fool ya, them puppies was BAD! BTW, is the 9C1 LO5 a 2 or 4 bolt?
Old 08-23-2006, 10:34 PM
BTW, you come get the whole car, I'll throw in a pre-90(?) s/b 350, no heads or intake, that started smoking, so it was pulled. I can get the casting #'s off it tomorrow...
Old 08-23-2006, 10:53 PM
silicon212's Avatar
Confoundingly Lucid
Unfortunately I'm in Arizona and I can't afford the trip to AR in either cash or time (although I've always wanted to visit that state and it would be cool to blow this place for a week or so) ...
What year Monte Carlo?
The passenger car L05 is a 2-bolt.
That 350 block - is it a one or two piece rear seal block?
Old 08-23-2006, 10:56 PM
Ah, Arkansas' a nice place, but the mosquitos and humidity make it rough... The Monte's a '96....No one wanted the poor girl, so I gave it a home..
Old 08-23-2006, 11:08 PM
silicon212's Avatar
Confoundingly Lucid
Ah, what's in your sig. You have the Northstar V8 in it?
Old 08-23-2006, 11:13 PM
I bought a '93 Caddy w/ the 4.6 in it, but I never had time to swap it in(I'm a mechanic), so I sold it 'n' now I'm waiting on the supercharged 4.4 Caddy engine. Somewhere around 500hp and 500ft lbs of torque.. awesome...
Old 08-24-2006, 12:58 PM
I figured it out! Apparently, according to GM, the '91(not sure about others) 9C1 350 uses corvette pistons. Some camaro's used them also. They shot me a price of $100 each! OUCH!!! And to the best of his knowledge, the wristpin is located in a different spot than on a stock 350 which would raise or lower the piston in the bore. So I may not be able to fix it, but at least I know why now. Anyone need a good '91 9C1 with a rod knock? LOL
