Old 08-21-2006, 10:54 PM
papiichuulo papiichuulo is offline
AF Premium User
95 chevy brake booster problem??
I am working on a '95 Chevy w/ a 305, 1/2 ton 2WD. Booster went out recently, replaced it, prob. went away. After a week truck came back with a different problem, operator says when he comes to a stop sign (sometimes) the pedal will not come back up and the brakes will not release. Give the trk some gas and it will barely move, let go and it will come to a stop by itself just like if you were braking. The prob. is intermittent. I have not been able to "catch" it in the act. Until recently that is, by the time I get to where the trk is, the pedal has released. I have noticed after a week in the shop, that the pedal will release when you kill the motor and then press on the brake pedal again. Could the new brake booster be the culprit? Any help would greatly be appreciated, thnx. L8RS
Old 08-23-2006, 08:46 PM
sreve sreve is offline
Re: 95 chevy brake booster problem??
sounds like a push rod adjustment problem on the new booster.
Old 08-24-2006, 08:35 AM
MyTOY's Avatar
MyTOY MyTOY is offline
Also check for restriction or kink in return line between
booster & pump reseroir and the return line is properly
installed. (per some tech info)
03 WRX
Old 08-24-2006, 08:42 AM
MyTOY's Avatar
after more research, it looks as though previous post
about pushrod adjustment is more likely. A preloaded
master cylinder from bad adjustment will lock the wheels.
03 WRX
Old 08-24-2006, 12:19 PM
AF Premium User
If it was a pushrod issue would the problem still be intermittent? I thought about that but figured that it would lock up the brakes as soon as it was put together. This problem comes and goes. It went a little more than a week between incidents.
