Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-21-2006, 10:43 PM
keely111 keely111 is offline
Tune Up Time
I have a standard 1999 (non police interceptor) Crown Vic. It's been an extremely trouble free vehicle.
I change the oil at 4000 mi religously.
I'm at 120,000 miles now and I think it's time for some TLC.
I always buy a car, take care of it and run the wheels off it into the 175,000 -225,000 miles.
I was going to
- Replace OEM plugs (what kind should I get)?
- Change Fuel Filter
- Transmission Fluid Change
- New spark plug wires (do I need to /what kind should I get)?
- New shocks all around. (any suggestions??)
- Do I need to have the injectors cleaned?
- Anti freeze flush & fill. This has the long life coolant - can I change that myself? Best brand to get?
Lately it's been having a difficult time maintaining an idle lately. I took off and carefully cleaned the mass air flow sensor and that seemed to do the tirck for a while.
Any other items I should be looking at?
Many thanks,
Old 08-22-2006, 12:03 AM
amo4387622 amo4387622 is offline
Re: Tune Up Time
I would get factory plugs motorcraft, you don't have wires to my knowledge you coils are over the plugs, And for the injectors I would go to autozone and buy a can of seafoam that stuff works great. As for the idle I would check the voltage at your TPS. I would also think about changing the fuel filter too.
Old 08-22-2006, 06:29 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Tune Up Time
Look closely at the boots on the bottom of coils. If they are cracked, dried out, or show signs of spark arcing through them, replace those also. Your idle problem may be the Idle Speed Control solenoid. Ford is famous for these going bad.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-23-2006, 05:40 PM
ghost1977 ghost1977 is offline
Re: Tune Up Time
I was going to
Many thanks,
if u looking for performce get axacel wires msd coil packs pvc sen trac shocks intake cleaner and spay and in thollte body and if u want sound get flow master 40 series mufflers duals
Old 08-26-2006, 04:47 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Tune Up Time
also replace the pcv valve and spray intake cleaner through the pcv hose to clean up the system
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 08-26-2006, 10:10 AM
Re: Tune Up Time
How about coolant?
My car has the long life type coolant? Is there any trick to flushing the system and putting new long life coolant in?
Mine is a standard CV (Not police) what size spark plug do I use?
