Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-21-2006, 10:21 PM
gpollard gpollard is offline
2002 Tahoe EGR valve
Does the 2002 Tahoe have an EGR valve? If so where is it? I look at the Haynes manual and it is not where the manual shows it.
garry
Old 08-22-2006, 12:00 PM
jthomp23777 jthomp23777 is offline
Re: 2002 Tahoe EGR valve
My 2001 Hoe EGR valve is right in front of the oil fill cap. Round with wire connection at top and two bolts.Should be cleaned every 60,000. Easy to do, disconnect wire and undo bolts. Clean it with a soft rag, cleaner or metal brushes not recommended. Just did mine, hope this helps........
Old 08-22-2006, 10:50 PM
thanks for the reply. I know where it is supposed to be just as you said but I don't have one.
Garry
Old 08-24-2006, 08:17 AM
Found this of interest. Look at your VIN-number. If you have a (Z) in the numbers ,usually the 8th digit from the right.Then there is no EGR valve in this particular engine. Its a flex-fuel system type. VIN numbers with the letter (T) and engine sizes 5.3 4.3,4.8,6.0 have a EGR valve. Hope this helps.
