Old 08-21-2006, 06:53 PM
TransManGLASS TransManGLASS is offline
97' Trans Am Turn Signal Flasher
Hey Guys,
I just purchased a 97' Trans Am and everything seems in working order...except ive got a little problem. My Turn signals rapidly pulsate when they should simply be blinking. Instead of blinking at an average speed of 2-3 seconds...etc it rapidly flashes several times per second. Is there something in specific that may be causing this strange behavior?!? Thanks well in advance for any advice.
-Dean
EDIT: Ive just read something about the hazards....ill test it out and get back to you.
Old 08-21-2006, 07:20 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Re: 97' Trans Am Turn Signal Flasher
Check your bulbs while you are at it, sounds like one or more is burned out.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 08-21-2006, 07:29 PM
79Bandit's Avatar
79Bandit 79Bandit is offline
yup thats just the car letting you know something isnt lighting up...
Old 08-22-2006, 07:57 AM
gmack221's Avatar
gmack221 gmack221 is offline
me three, you have a burnt out turn signal bulb, change it and things will go back to normal.
Old 08-24-2006, 06:51 PM
98gpking 98gpking is offline
Send a message via MSN to 98gpking
Originally Posted by TransManGLASS
Hey Guys,
-Dean
hey while your inside the front bumper if i might recommend getting clear corner lights. they can be found at afterthoughtsauto.com they are about 55 bucks. highly recommened and everyone....and i mean EVERYONE will ask where you got them from people would never stop asking me
Old 09-22-2006, 01:21 PM
stephenie/tn stephenie/tn is offline
Don't know where to ask question, so will do it here. I have 99Trans Am. Can't find where the T/S Flasher goes. Help needed by poor little ole helpless southern girl. Thank you guys.
Old 09-22-2006, 01:26 PM
you mean like as far as replacing a bulb??? or getting a whole new set of lights??
Old 09-22-2006, 01:27 PM
Old 09-22-2006, 01:58 PM
The lights/bulbs are fine. When I turn on the signals to make a turn, they flash once every 2 miles. So I figured itr was the round Flasher thingie that needed replaced. I bought one, but I can't find where it goes. It is not in the fuse box on driver side of dashboard, it doesn't appear to be under the dash; where is it hiding? TY for asking, please help me. I almost got t-boned cause signals don't work. stephenie/tn
Old 09-22-2006, 02:01 PM
gmack221's Avatar
Turn Signal Flasher, not lights dude ...
stepenie ... it will be under the dash near the steering column, easiest to find if you remove the pannel under the steering column, its like 4 screws and is heavier then it looks. once you have that pannel removed and have your new part you can start looking for it (turn on the turn signals if they still flash, if not turn on the 4-way flashers). They use 2 flashers, one for the turn signals & one for 4-ways, make sure you change the right one. they should be clipped to the dash on the left side. good luck and have the new one there so you know what your looking for, buy the heavy duty one its worth the extra $1. any more questions reply back, good luck
Old 09-22-2006, 02:02 PM
whats the exact name of the part your ordered....i think i know what your talking about but there could be a few parts that im thinking of which are all located in different places.
Old 09-22-2006, 02:20 PM
Thank you so much, such a sweetie. Will get back if I have troubles. HAGD stephenie
Old 09-22-2006, 02:23 PM
Old 09-22-2006, 02:26 PM
Thank you for ur response. I am checking out what '97 said to do. Then if that doesn't work, we will talk. HAGD stephenie
