Old 08-21-2006, 03:40 PM
atv087 atv087 is offline
Send a message via AIM to atv087 Send a message via Yahoo to atv087
86 escort failed emissions got any ideas?
failed nys emissions today so i didnt get my inspection. here are the readings
HC:1.19 gpm CO: 23.34 gpm NOx: 0.16 gpm
test limits HC:0.80 gpm CO: 15.00 gpm NOx: 2.00 gpm
so i failed on hydrocarbons and whatever CO is
any ideas what could cause this so i can pass inspection.
Old 08-21-2006, 04:40 PM
markwb's Avatar
markwb markwb is offline
Re: 86 escort failed emissions got any ideas?
CO is carbon monoxide. My first thought would be catylitic converter possibly failing. Or the egr system is not functioning correctly. What did the emissions tech tell you?
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 08-21-2006, 05:26 PM
12Ounce 12Ounce is offline
I agree with Mark, it looks like you've got ten times the EGR that you need. Is the valve stuck open.. or is the vacuum control signal on all the time?
Does your model have the air pump that pumps air into the exhaust system? Is it working?
Is this a carbureted model?
Old 08-21-2006, 06:16 PM
this is carburated model. it sat for about 4 years the guys recomendation was that it needs some real good fuel system cleaner pour 2 bottles in and fill the car up with super and run the shit out of it bury the speedomiter a few times to flush some of the stuff inside the fuel lines and carb etc. then run a bottle of the pass emissions stuff and when that tank of gas is almost done get the oil changed fill up and come for inspection again.
Old 08-21-2006, 08:19 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
You EGR valve comes off easily. It will be worth it to remove it and verify that the plunger inside opens and closes... just apply vacuum and listen for the movement. Considering the age of the car and that it sat for so long... it is very possibly stuck.
If it is stuck, you an probably use a lubricant to free it up.
Old 08-22-2006, 11:15 PM
wheres the egr located on this car?
Old 08-22-2006, 11:59 PM
You should find a metal tube that connects to your exhaust manifold or cat converter... follow that tube around to the back of the engine where it will connect to the EGR.
Old 08-23-2006, 08:25 AM
You can possibly do some good by opening up the carb. Carefully remove the top half ... don't loose that small tag under one screw head (if it's still there) that identifies the carb model.
Use a battery filler (turkey baster) rubber syringe to swish the gasoline around in the float bowl. Try to blast all the openings. Suck out the debris. If you remove the jets ... do it one-at-a-time so you don't get them in the wrong hole. Look out that you don't lose or damage anything.
Old 08-24-2006, 04:07 AM
paqman's Avatar
paqman paqman is offline
I saw mention of putting a fuel system cleaner in. I agree. I had a Pontiac GrandAm once that wouldn't pass emmissions. I put a can of 44K in a full tank of gas, drove it around for about 20 minutes and she passed. I'm not a mechanic, so I'm not sure if that will solve your problem, but it might be worth a try.
Current Vehicles:
2008 Nissan Altima ~ 115k miles
2010 Nissan Maxima ~ 74k miles
2007 Toyota Sienna LE ~ 145K miles
Goners
1997 Ford Escort ~145k miles (SOLD)
2013 Kawasaki Ninja 300 ~13k (SOLD)
1983 Honda Magna V45 ~13k (SOLD)
2004 Mazdaspeed Miata ~90k (SOLD)
2001 Ford Mustang GT ~86K (SOLD)
2007 Suzuki Boulevard M50 ~12k (SOLD)
2001 Nissan Maxima - (TOTALLED)
2001 Oldsmobile Intrigue (SOLD)
1991 Nissan Maxima (TOTALLED)
1989 Pontiac Grand Am (SOLD)
