Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-21-2006, 01:55 PM
Ford hater's Avatar
Ford hater Ford hater is offline
Question Getting more power out of the V6
I have a 95 century with the 3100 sfi v6 power plant I would like to some more out of it any suggestions beides boring the cylinders?
mopar or no car
Old 08-22-2006, 12:06 AM
doberman_52's Avatar
doberman_52 doberman_52 is offline
Send a message via MSN to doberman_52
Re: Getting more power out of the V6
Cold Air Intake and exhaust would be a start to give it a little more power. I've been trying to ask the same thing with my 3.3 v6.
Old 08-23-2006, 01:38 PM
Ford hater's Avatar
I already have a walker high preformance exhaust and a thrush turbo muffler on this thing already.
I wondder if I could get my computer upgragded on it and get a super charger along with that to?
mopar or no car
Old 08-23-2006, 04:27 PM
I know that on mine, I have the 3300, you can put the 3800 plenum, injectors, fuel rail, and supercharger on it. I would then have to re-map the computer. I would if i had the time and money right now, but i don't.
Old 08-28-2006, 01:34 PM
90BuickSlab's Avatar
90BuickSlab 90BuickSlab is offline
You could get a superchip...at least for the 3.3 & 2.2
Old 08-30-2006, 01:53 PM
I've thought about that, but they are hard to find and I don't have a lot of money rigt now. Do you know of any others?
Old 08-31-2006, 09:01 PM
GaryFenza GaryFenza is offline
How much power you looking to get out of it, after all it is a Buick Century, not exaclty supposed to be "fast and Sporty"
Old 09-01-2006, 10:55 AM
It is acctually quite a fast car for being dubbed as a "grandma car ". I have only done exhaust on it and I know it can do 120mph. I'm not sure how much power I would want to get out of it but I do want to turn mine into a performance car, maybe a sleeper, drop a V8 in it.Do you know af anyplace where you can get performance cams, pistons, injector or anything else? Maybe around 400-500hp, if not, more. If I do, I would also remove the ac system and try to shave of as much weight as possible, add k&n cai.
Old 09-01-2006, 03:43 PM
sounds awesome...i know mine can do around 120 on flat ground, and i pushed it to approx 130 down a hill. what makes it fast is the great throttle response, and its o 3 speed w/ no overdrive.
Old 09-01-2006, 04:15 PM
i have the 3 speed w/out overdrive but I actually think I was pushin 130 flat ground a few weeks ago, but i'm not sure. It's hard to tell with the stock 0-85mph old style gauge that is flat not round.
Old 09-02-2006, 12:28 PM
I hate the stock speedo, they couldnt've made it go at least to 100...
BTW if you would push 300-400hp out of a century, what would you do about the handling???
Old 09-02-2006, 06:52 PM
I don't think the handling is really that bad but I would mainly drag with it.
Old 09-04-2006, 02:57 PM
Ford hater's Avatar
For my handling I put preformance struts and shocks with my own custom mounts on it and it does pretty good for a so called "grandmas car" I found a super charger for it and got it I lokked at apreformance chip and the price was any thing but pretty But i finnaly got the super charger for it and found out the hood is to small there aint enough clerance agggh but I took it out for a spin and it had great get up and go.
mopar or no car
Old 09-04-2006, 05:22 PM
what did u do for ur custom mounts? Also another thing that u could do is get a different set of pistons and connecting rods to make a higher compression, put on bigger injectors (I might this month),lighten the car (not sure how though)just a few more ideas
Old 09-05-2006, 01:14 PM
Ford hater's Avatar
For lighting it Im going to use custom fabricated carbon fiber body panels it will set me back a fortune but it will make it lighter by about 200 lbs
mopar or no car
