Old 08-21-2006, 01:29 PM
lminton lminton is offline
check engine light blinking
my 98 3.8 oldsmobile intrigue has the check engine light blinking. i drove it pretty intensely this summer, putting about 4,000 miles in the past 3 months. it was driving fine, even yesterday on a long trip. but when i started it up a few minutes ago, the car was shaking a lot and the check engine light started blinking. it also smells kinda weird. any takers?
Old 08-21-2006, 02:42 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: check engine light blinking
Welcome to AF.
How many total miles on the car?
Whenever the SES/CEL light blinks it indicates that a misfire condition has been detected by the PCM module. Start with spark plugs and wires if you have not already replaced them. Use OEM GM/AC Delco only.
Timeslip 08/12/06
AF Community Guidelines
Old 08-21-2006, 02:55 PM
theres about 115,000 miles. problem is, i am kinda clueless as far as cars go. i mean i checked to make sure the belts weren't loose, checked the oil, etc. i made sure the spark plugs weren't loose or funny looking, but i don't know how to change or check them. how much does it cost to get them replaced?
Old 08-21-2006, 03:03 PM
BNaylor's Avatar
With over 100K miles the spark plugs and ignition wires are due for replacement. Most misfire problems are corrected when these two items are replaced. I am not sure what a GM dealer or a general mechanic/shop charges because I do my own work. You can get the ignition wires from an AC Delco Authorized Parts Dealer for around $60 and the plugs range around from $4 - $8 depending on whether AC Delco Platinum or Iridium.
Timeslip 08/12/06
Old 08-21-2006, 10:18 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
NGK plugs should work fine as well. I am currently running a set and have had no problems
I would also recommend the Belden wires from NAPA,lifetime warranty and a decent price, and yes I have used them before, on my previous car a Bonneville with the 3.8.
Old 08-21-2006, 10:25 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
This happened to my daughter's '98 Intrigue one time. Just out of the blue - same thing as you describe. It ended up being a 'stuck wide open' injector that was just dumping tons of fuel into one of the cylinders. In her case I told her not to drive it until I checked it, and I'm glad she didn't 'cuz there was raw fuel that had dumped into the converter and exhaust system - it took a little while to clear it out and we were lucky that the cat wasn't damaged.
Of course your problem may not be as serious as this, hopefully.
Old 08-22-2006, 02:43 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: check engine light blinking
At 115k plugs and wires are the #1 choice, I have had bad experiences with anything but oe type plats or iridium AC plugs, a premium wire set is required here also as the combination of underhood temps and the ign potential of 80k volts demand the best.
Old 08-22-2006, 08:13 PM
Rolm's Avatar
Rolm Rolm is offline
I agree with the above, and yesy stick with A/C parts and most of all make sure you use nothing but the same plugs as the orginals. Tha same happened to my 3.8 My mistake was I took it to a dealer and it cost me around $700.00 to change , Plugs, wires, clean the injectors and intake and replace both filters. I think they call it a super tune-up. Oh yaw I can't believe how smooth the engine is running and I noticed great gas milage.
