Old 08-21-2006, 10:27 AM
reodom reodom is offline
Fuel gauge malfunctioning
I just bought a 2000 Blazer 4wd at an auction. It has 97k on it and i had to have the transmission rebuilt. After that, the only problem i notice is the fuel gauge doesnt seem to be working correctly. it works fine from a full tank to a half a tank, but then doesnt go anywere. The other day on a road trip the gauge read half a tank but I had driven 190 miles. Any help you guys could give me would be great. Thanks
Old 08-21-2006, 10:51 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Fuel gauge malfunctioning
Most common cause is sending unit
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 08-21-2006, 06:20 PM
Ultrashock's Avatar
Ultrashock Ultrashock is offline
I agree I have the same problem
I just use the trip meter as my fuel guage
92 S10 Blazer Sport
4.3l Vortec V6 (W)
275,000 miles
Jasper engine, Rebuilt tranny + rearend
04 Pontiac Grand Prix GT
43,000 miles
Old 08-22-2006, 12:34 AM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
If it is in fact the sending unit you might as well just wait until the fuel pump goes out. Dont you worry because sooner or later it will go out. The just do the entire assembly at once. I just say that because there is really no need to drop the tank if you dont have to. But then again thats just my opinion.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 08-23-2006, 03:09 PM
jhsmith246 jhsmith246 is offline
has anyone replaced the fuel pump and sending unit by sawing through the rear floor area? I did that on my camaro by following an internet fixit guide.
will it work on the blazer?
thanks.
Old 08-23-2006, 08:15 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
I've seen this done, and I have to say its the most stupidest thing you could do. If you have an accident, gas can get in, fire risk, carbon monoxide risk, the list goes on and on....
Old 08-23-2006, 11:30 PM
i tried it on my z28 like this and it seemed to be fine with heavy gauge steel plate, plenty of liquid gasket (red) and I put in 20 sheet metal screws to hold it down. seemed stronger than original body but rollover risk would be higher with the blazer so maybe fuel could get in.
http://www.geocities.com/formulapower2/fuelpump.html
Old 08-24-2006, 11:04 PM
BlazinMlew's Avatar
Why saw through the floor when it only involves dropping the tank? Seems to me like it would be more work, not to mention dangerous, to saw through your floor and then have to replace the hole you just cut. ?????
Old 08-24-2006, 11:22 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
I Agree.
The first time I dropped the tank on my '97, it took me 5 hours from start to finish.
The second time, it took me less than 3 hours from start to finish.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 08-25-2006, 10:22 AM
frankjc frankjc is offline
Cutting a hole in the floor, then having to patch it back up is more work than taking the fuel tank out. I can't see any benefit to doing it that way.
Old 08-25-2006, 11:28 AM
rather than call it a hole, i like to think of it as an access panel. i've done fuel tanks on other chevy's (e.g. astro van) and just seemed a whole lot easier to sit comfortably in back working downward than laying under car trying to wrestle the tank upward. as to danger of cutting hole over tank--tank must still be drained and one must be just as careful drilling first hole as placing jack stands on raised car or removing air bag units--if not done carefully, disaster can always occur.
bottom line--sounds like most of you drop the tank.
thanks,
jeff
Old 08-27-2006, 10:32 AM
bhesson bhesson is offline
If and when you decide to replace it, this site has the pump/sending unit for alot less than it would cost at a dealer.
The part# is 25176789
http://www.gmpartsdirect.com/
Old 08-27-2006, 08:25 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yip, sending unit.
The unit in the tank gets stuck at half way or is fouled.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-28-2006, 01:10 AM
do you have part no for fuel pump also, may as well change that if changing sensor.
thanks,
jhsmith246
Old 08-28-2006, 02:30 PM
BlazerLT's Avatar
AF -Advisor
It might come as one unit with that year.
Some years the pump was the whole assembly.
Make sure you get AC Delco only for the pump, do NOT cheap out and get Carter or something or you will be sorry.
