Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-19-2006, 11:30 PM
capriceowns capriceowns is offline
Fan clutch
How do you know if a fan clutch is bad?
mine is starting to rust all around it, and its making a squeaking sound when the car is running, and doesnt increase when acceleratingg.
Old 08-20-2006, 12:33 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Fan clutch
Replace it. THey're cheap and it beats having a fan penetrate the radiator.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-20-2006, 01:39 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: Fan clutch
yeah they are cheap at your local auto parts store, they dont last forever, i would have to say probably at least 33% if all of them on the road right now are worn out due to higher mileage and/or age, or both, is a common occurance to find a worn out clutch fan, most are viscious fluid type some are tempered wound spring type only and some are both, most are both or viscous fluid type only
if there is nor or little resistance in turning the blade set by hand when the engine is hot then its toast, time for new one
they are supposed ot lock in at low RPM and hot, so tat it will cool the fluid in the radiator at those lower speed and hot times
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 08-20-2006, 04:40 PM
TommySS TommySS is offline
Re: Fan clutch
Do NOT get the "heavy duty" fan clutch. I lost a significant amount of horsepower (84 wagon H-series 305) thinking that bigger was better.
I went back to a standard duty fan clutch and it was like adding 25hp.
