Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 08-19-2006, 09:01 PM
Jeanine Coleman Jeanine Coleman is offline
Many problems with my computer system and car in general
Occasionally this happens:
1. Dcl warning beeps and all of right screen ------ doesnt read
2. Oil pressure warning beeps
3. Check engine warning
4. Speedometer goes out
5. Battery being drained
Also I am having problems with my brakes I am told that the back brakes wont bleed there is air in them.
While riding my ride control (airbags?) messes up.
I have a 94 cont ex power everything
Please help!
I live in Maryland does anyone know a good mechanic that works on fords?
Old 08-24-2006, 03:09 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Many problems with my computer system and car in general
Those electrical problems sound like a defective alternator.
The brakes may just need the Caliper Pistons adjusted. Another guy here had the same problem, mechanics insisted there was an Air 'in the lines" problem. It turned out to be Caliper Pistons weren't setup properly.
-Steven
1996 Town Car, Cartier
Old 08-24-2006, 11:39 PM
I have had the front caliper replaced but not the back are you saying that maybe I need both back calipers adjusted? I was told that it had to be hooked up to a computer that only the ford dealership has and that this computer will make the computer think the car is in driving mode so that the air can be removed from the back brakes. Something about the valve only opens when the car is moving and that is the only way to remove the air from the rear brake lines.
Old 08-25-2006, 11:52 AM
Towncar's Avatar
Electrical problems aside for now....
Jump over to this thread and have a look at the discussion for a similliar problem.
You're welcome to join there as well, plenty of good 'ol boys to answer your Q's.
-Steven
Old 08-23-2007, 07:06 AM
lmoney1975 lmoney1975 is offline
i buy and sell cars Im from northeast maryland and i have a excellent machanic thats very reasonable in price please contact me 443 207 2460 ask for lloyd
Old 08-23-2007, 08:10 AM
boltswagen's Avatar
boltswagen boltswagen is offline
These are famous for bad connections on the back of the instrument cluster causing all sorts of alarms, beeps, and weird readings.
Maybe have your mechanic pull the instrument cluster (not hard) and clean all those plug-in connections, especially the flat copper ribbon connector and plug on the back.
This fixed my '94 with a false oil pressure warning.
Of course, if you really do have low oil pressure you can't run the engine without destroying it, but I took the risk on mine that it was indeed a false alarm because it was so random and had nothing to do with temperature or RPM.
Rob
These are my opinions. I'm not a mechanic.
