Old 08-19-2006, 08:48 PM
springvilleland springvilleland is offline
95 Voyager failed Emissions
my 95 Voyager failed emissions because they said it smoked too much they said it might pass if I put that stop smoke in it or it would cost over $2,000 to fix it right please help I am a single mom and can't afford that much.
Old 08-19-2006, 11:03 PM
Bernard Feltzer Bernard Feltzer is offline
Re: 95 Voyager failed Emissions
What kind of help do you expect?
Some kind of magical genie to make the smoke disappear?
Your van is burning oil, rings on pistons are shot, or valves are burnt.
Get a new van. The end.
Old 08-20-2006, 12:28 AM
Mrgonzo1 Mrgonzo1 is offline
If you can, have a compression test done to check the condition of your motor. A compression test can narrow down the problem to either worn rings (worst case) or leaking valve seals. Unfornately the cost will still be an issue. It may be more economical to get a used vehicle if you cannot afford to fix your van.
Old 08-20-2006, 09:21 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Welcome to AF!!
How many miles are on your van? Unfortunately as engines wear they will burn oil. Seals or rings can be the cause of the smoking. You can try several products especially if it is a ring issue. Restore used in the oil will decrease oil consumption. There are other treatments that will condition seals and possibly stop the smoking but unfortunately, you may need to to do some major repair work to get the van to pass emissions.
