Go Back   Automotive Forums Car Chat > Buick > Regal
Old 08-19-2006, 07:17 PM
smurfy1313 smurfy1313 is offline
pully
getting at pully boys pully think netween the 3.0 and the 3.25 any idea
Old 08-19-2006, 09:58 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: pully
What mods do you have to support a supercharger pulley that small?
Timeslip 08/12/06
AF Community Guidelines
Old 08-20-2006, 12:18 AM
Re: pully
what mods do i need
Old 08-20-2006, 08:19 AM
BNaylor's Avatar
Re: pully
Originally Posted by smurfy1313
what mods do i need
The biggest problem with adding a 3.0 - 3.25" SC pulley is knock retard (KR). You'll have to run colder spark plugs (two ranges). Intake and exhaust mods are required. A re-programmed PCM module from DHP or ZZP will be needed.
Otherwise you will damage the engine and due to the PCM changing advance and timing when KR is detected the car will run crappy.
3.4" is the safest pulley size you can use without the required mods. All you need to do is go one range colder on the spark plugs.
Timeslip 08/12/06
