Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-19-2006, 03:19 PM
Woowagon Woowagon is offline
'99 Passport trans filter change
Just completed the test drive after changing the filter and fluid this morning. I used a Pioneer Automotive Products filter kit from Advance Auto (web site order only, PN 745079). I picked this one because they claim to use OEM filter media, it was a pretty good price, and has a silicone rubber gasket. I refilled with Valvoline Max Life because it was cheap and easy to get. And because we have 90,000 miles on it, there are the beginnings of leaks and this stuff is supposed to help "revive" the seals.
First off, I should have done most of the work (except resetting the fluid level) on ramps or jack stands. It would have saved a LOT of time wiggling around on the floor.
Second, there are two fasteners at the back of the pan that are not quite as easy to get to as one would like. The right one was a big pain because the trans crossmember is too near to the pan lip to get a straight shot. I finally got it with a frankenstein setup of flex-handle ratchet, short extension, universal joint, short extension, short socket. Going back together, the pan sat back so there was even less room for the ratchet setup until I prised the pan forward again.
Third, filling was a pain. God forbid, they put the fill plug in the side of the pan. Oh well, I rigged up a pump that screws onto the fluid bottle with a hose on the end long enough to snake up in to the pan. It took about 6 1/2 quarts going by the service manual's procedure.
The filter appears well made, identical to original. The gasket also is nice. The screw holes are undersized. You can lay the gasket on the pan, push in the screws, and install the pan without the screws falling out. Heat from operating the vehicle is supposed to fully cure the gasket material for a better seal. We shall see about all of their claims.
Tomorrow, I will check the pan screws again and then recheck the fluid level. Hopefully, I can forget about the trans for a few years now.
Old 08-19-2006, 06:37 PM
surferfletch surferfletch is offline
Re: '99 Passport trans filter change
Ahhhh. Brings back memories. Only 7K before I do mine again!
Old 08-19-2006, 07:05 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
how did the old filter look?
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 08-19-2006, 08:42 PM
I did not open it up but, looking into the opening, it was MUCH darker than the new one. I have never changed the fluid, let alone the filter in the 89,987 miles it had before the work today.
The fluid and swarf I cleaned from the pan and magnet smelled hot/burned somewhat. It was obviously "time" to do it all.
The first drive was an easy one, just about ten miles. At first glance, it does shift more smoothly; we'll see in the days ahead if that is reality or just in my head.
Old 08-20-2006, 11:23 AM
marcre's Avatar
cool, thanks for the reply. Don't forget to check the level of ATF a few more times. Definately want that as close to perfect as possible.
marc
My Rodeo
Old 08-20-2006, 11:41 AM
The pan fasteners were good, no runs, no drips, no errors, and the level was perfect. I'll check everything again in a month or so for giggles.
Next problem to solve is the hard starting. That'll have to be a different thread.
Old 08-20-2006, 01:36 PM
marcre's Avatar
I've had the hard starting since I bought my Rodeo over two years ago. It comes and goes, so I live with it. Can't seem to pinpoint the problem, so hopefully it doesn't get worse.
marc
My Rodeo
Old 08-20-2006, 08:59 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
I feel your pain. I did mine a little over a week ago. I used a 10mmm racheting wrench on the 2 hard to reach bolts. You have to come at them from a 45 degree angle around the crossmember. The PITA was reattaching the pan.
My filter was covered with sludge and metal shavings. I couldn't even see the magnet. I even did 2 more drain/refills, but the tranny keeps slipping. I'm taking it to a local rebuilder to get a diagnosis.
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 08-21-2006, 07:03 AM
Ramblin Fever Ramblin Fever is offline
Pharm Rodeo - FWIW, I don't know if I would *rebuild* the 4L30-E transmission, they typically only last a year to 2yrs by doing a rebuild. Your best bet is to look for a low mileaged used one, many people that have done rebuilds find themselves in the same boat within a year.
It's the design of the transmission that doesn't allow the rebuild to hold very well.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-21-2006, 09:29 PM
The main reason I am going with a rebuild is b/c this shop is offering a full 3 yr/36,000 warranty. That's actually better than most shops that want to swap out. It just seems almost impossible to find a reputable tranny shop. I've looked into so many shops my head is going to explode. Unfortunately, I have to bite the bullet and get this issue resolved.
FWIW, I personally believe that ppl who get this tranny rebuilt still continue to neglect it. I guess ppl assume that once it's rebuilt it never needs to be serviced. If I spent 2k on rebuilding a tranny you better believe I'll checking that fluid level every other oil change. I'm just paranoid..lol.
Old 08-22-2006, 12:48 AM
TRUST me, you're not the only one! I just changed out a perfectly good OEM radiator from what I can tell, just because I felt going on 10yrs was too long for it. Still looks to be in REALLY decent internal/external shape. Figured with all the dirt roads, muddy river beds, sandy beaches this trucks been on and through that the lower part of the radiator, if anything, would be dented up and such. Gonna keep it around a while, just incase.
You're probably right about the neglect on the rebuilds - course you never hear of people admit that part
Good luck to you - keep us posted, eh?
1997 3.2L V6 Rodeo
Old 08-22-2006, 09:27 AM
One issue that has now been solved is the sluggish engagement after sitting a while. It was starting to take a second or two to actually engage if the vehicle sat more than a day and a half. There are no leaks just dampness so that is why I suspected the filter. I just drove the car after letting it sit for almost two whole days with no hint of this now.
The trans also shifts smoother now. I thought it was smoother immediately after the change and I am certain of it now.
I will check back in on the thread in a month or so with an update.
Old 09-04-2006, 08:25 AM
Just an update to say that the filter and fluid change has made a great difference. The "lag" in engagement (read back) was gone immediately (noticeable right away). But the shift quality has also been improved greatly. I really noticed this yesteday during a long drive. The shifts now happen more quickly and are smoother as well. If you have not yet, and your mileage is nearing 80,000 or more, CHANGE THAT FILTER!
Edit: Oh yeah, I would highly recommend the Pioneer Automotive Products filter kit from Advance Auto (web site order only, PN 745079). I repaired two broken/loose exhaust heat shields yesterday and took a good look at the pan again. Absotively, posilutely dry.
Old 09-04-2006, 09:34 AM
2000izusu 2000izusu is offline
Good to know. every time i change mine (every 10,000 miles ,i know i'm paranoid) my shifts get very much better. it makes a big difference and i can feel it!. i have not changed my filter yet but i will do it soon.
woowagon is the filter a screen, like another auto i own or is it fabric like?
thanks mike
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 09-04-2006, 11:11 AM
Here is a link to Advance Auto's page for the filter:
http://www.partsamerica.com/ProductD...e=1158&ptset=A
If this link works, you'll see the filter is a plastic case with a oval shaped "pickup tube". The filter media is a fabric that looks somewhat like felt.
