Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 08-19-2006, 03:12 PM
djsung815 djsung815 is offline
Send a message via AIM to djsung815
02 New Beetle 2.0 GLS: Red Temp Light
whenever i start the car, red temperature light comes on and starts beeping. this light is supposed to be blue when engine's cold, right? beeping goes away after a few beeps, but the light continues to flash for the next few minutes, then eventually goes away.
this used to be a once a week thing, but now it's every time i start the car.
what's wrong with my car?!?! please help.
Old 08-24-2006, 02:57 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 02 New Beetle 2.0 GLS: Red Temp Light
bad coolant temperature sensor
Old 08-24-2006, 03:33 PM
is this an easy fix? if so, what do i need and how much would it cost? thank you very much.
Old 08-27-2006, 06:40 PM
bugwugly bugwugly is offline
Send a message via AIM to bugwugly
Unhappy Re: 02 New Beetle 2.0 GLS: Red Temp Light
I have had this same problem with my 2000 beetle. I replaced the ect sensor and the result did not change. However, after I replaced the water pump the problem went away. Also, remember to replace the timing belt at the same time
Old 02-29-2008, 04:06 AM
hako hako is offline
A new coolant temp sensor is not expensive - maybe $AUD40 and clips into the coolant hose near the air cleaner. Change that and hope the rest is OK.
Old 02-29-2008, 02:38 PM
Kirk in Iowa Kirk in Iowa is offline
Depending on the exact symptoms, this thread may help too. May not be a bad sensor.
http://www.automotiveforums.com/vbul...d.php?t=750432
Kirk
