Old 08-19-2006, 12:18 PM
Emmitt101 Emmitt101 is offline
How Do I Know Which Belt To Use
I have a 97 Grand Prix SE and it seems there are two different size belts. One is 93" and the other is 93 1/2". How do I distinguish which one to use?
Old 08-19-2006, 01:26 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: How Do I Know Which Belt To Use
That is correct. There is a first and second design serpentine drive belt for the '97 model year. It depends on which alternator you have and its pulley size and whether you have a 3" tensioner pulley. Most '97 SE/GT/GTP with the Series II 3800 engine use the longer 93 1/2" belt but you may have to take your belt off and measure it to be safe.
Gatorback Gatorback Part # 4060935 93 1/2" BELT - Matches AC Delco 6K935
Gatorback Gatorback Part # 4060930 93" BELT - Matches AC Delco 6K930
Timeslip 08/12/06
AF Community Guidelines
Old 08-19-2006, 01:31 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: How Do I Know Which Belt To Use
Just to add to Bob's usual comprehensive info, the last 3 numbers on the belt are the length, check your old belt this way and match it up.
Old 08-19-2006, 01:48 PM
BNaylor's Avatar
That depends Shep. If he has the original GM OEM serpentine drive belt or an aftermarket other than like the Goodyear Gatorback or AC Delco branded he probably won't be able to tell or go by that.
For example an original GM belt never replaced may be marked like this:
GM 24506524 SGR 6PK2327 EB
BTW - Here's the part number breakdown of a GoodYear Poly-V belt:
Functional Part Number Gives You The Size Of The Belt
EXAMPLE:
4 06 049 5
1st digit (4) represents a K section Poly V-belt.
2nd and 3rd digit gives the number of ribs.
4th, 5th, and 6th digit are the length in inches.
7th digit is tenth of an inch.
Part number 4060495 would be a K section Poly-V belt, six ribs wide, with a length of 49 and 5/10 inches.
Timeslip 08/12/06
Old 08-19-2006, 02:12 PM
Thanks, The old one was a 93 1/2 and for some reason it just slipped right off the tensioner and pulleys. Could it possibly have stretched somehow. I know the tensioner is good because I replaced it last year and everything else is tight.
Old 08-19-2006, 03:31 PM
A990 racer
Red face Re: How Do I Know Which Belt To Use
EXAMPLE:
4 06 049 5
Bob a lot of the oe belts I see have the oe mfg part number then the actual mfg of the belt has their number which translates to the size, but I may be seeing other than GM belts here, memory is some what less than perfect these days. Shep
Old 08-19-2006, 03:33 PM
BNaylor's Avatar
When you get the new one it should feel tighter. The belts stretches over time and also develops those cracks along the inside. You might consider just using a GoodYear Gatorback. Excellent drive belt. Good luck.
Alot of variables Shep but if you notice from the info posted on the GoodYear Gatorback belts it is hard to go wrong with that brand and that conforms to what we have been discussing.
Timeslip 08/12/06
Old 08-21-2006, 08:48 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Goodyear belts are great. They have a staggered ridge design that does two things. It prevents cracks from developing in a straight line across the belt causing a weak point, and it keeps the belt cooler by increasing surface area. A much improved design over smooth ribbed OEM belts. Nice write-up on the part number breakdown Bob, that should assist those modding their cars with undersize pulleys and such. I sell Goodyear belts where I work, and your breakdown is spot on (of course).
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
