Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 08-19-2006, 10:00 AM
HarryR HarryR is offline
1994 Tailgate wont open.
The key will turn in the lock but the tailgate will not open. Is there a way to access the mechanism from the inside? Any other suggestions?
Old 08-19-2006, 02:20 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 1994 Tailgate wont open.
Try to push in on the liftgate, pull out on the handle and lift the tailgate.
If that don't work give it a coupl ehard pounds next to the handle then lift it.
Once you get it open you will want to saturate the latch/lock mechanism with WD-40, pB Blast, etc....
There is a thread on here somewhere, where someone unbolted the striker from underneath the jeep and opened the liftgate so they could remove the panel to get the latch unstuck.
Old 08-20-2006, 10:03 PM
breeaad breeaad is offline
Had the same problem with my 98 JGC. The latch looses adjustment over time due to the plastic mechanism wears. If you can't open it, crawl in the back and get as many screws as you can out of the cover. You can then slide your arm inside the hatch and open it. Then take the entire cover off and peel back the moisture barrier. You can now adjust the latch. You will have to play with the adjustment until it works properly.
Old 08-21-2006, 01:35 PM
Maui_Dave's Avatar
Maui_Dave Maui_Dave is offline
Been there. Done that!
http://www.automotiveforums.com/vbul...d.php?t=548557
Old 08-21-2006, 03:36 PM
Thanks all for your help. I did manage to get the tailgate opened but now want to fix a problem with the lock mechanism. When you put the key into the lock it pushes into the tailgate. When I look from the inside of the tailgate panel I don't see anything that holds the lock in place. Nothing loose inside the panel and my son bought this used so this problem has been there a while. Is there supposed to be a spring clip that slides into a slot I see that would hold the lock assembly in place? I can't find any kind of schematic on the tailgate or lock assembly to see the list of parts.
By the way the original problem was corrosion as you guys suggested.
Thanks.
Old 08-21-2006, 08:34 PM
Maui_Dave's Avatar
Harry,
My 96 had a stud on the latch assembly (lock cylinder's part of the assy)
There's a nut on the inside of the liftgate. You're 94 might be different though.
Old 08-24-2006, 12:04 PM
Dave - I sent you an email to try and more fully explain the problem. Thanks for your help. Harry
