Old 08-19-2006, 09:10 AM
rnelson rnelson is offline
98 buick squealing
boy i should have read more on auto forums i had a plenum put on my car a week ago then the squeling started a good mecanic said bearings in alt so put on new one still squealin so i know it was water pump put on new one wasent that put on belt not that put on belt tentioner not that so i took off the belt started it up still squealed i pulled out the new p v c they send with the ken co plentum thay was my noise now some one tell me why the p v c would squeal any one want know how change a water pump give me a email pelzerbob@ aol .com
Old 08-19-2006, 10:11 AM
imidazol97 imidazol97 is offline
AF -Advisor
Re: 98 buick squealing
The PVC has a rubber o-ring gasket on it. I don't know if it's one or two. I believe I've heard people having a squealing from the air being sucked around it if they left the original o-ring in and put in the second o-ring or left both o-rings out.
Who has changed theirs? I did but it was 80K miles ago... I've long forgotten.
Old 08-19-2006, 10:30 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Series I PCV for me... so I don't know anything on that.
As for other possible sources, what is the condition of the harmonic balancer? It usually just vibrates like crazy vs making a squealing noise, but it is still worth looking into. If you remove the belt and grab the HB, and try to move it side to side there should be no slop....if there is then the rubber holding the sections together has deteriorated and the HB must be replaced.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 08-19-2006, 04:15 PM
BNaylor's Avatar
BNaylor BNaylor is offline
rnelson,
How about doing something about your sentence structure and at least put a period after a sentence. Thank you for your cooperation.
POSTING EDIQUETTE:
AutomotiveForums.com is a professional community where members expect to read posts with correct grammar and practical sentence structure. Any posts in all caps, and or funny mixed case such as "hey can u c thiz? L8r!" will not be tolerated. The same goes for language. AF is an English language based site. All discussions should be conducted in English. If you cannot post clearly, coherently, and in English, you will be given notice to do so. If you ignore this notice and continue to post incoherently, your posting rights will be removed.
Timeslip 08/12/06
AF Community Guidelines
Old 08-19-2006, 06:24 PM
AF -Advisor
What happens when you take off the oil cap when the motor is running? Is it sucking in air?
Old 08-19-2006, 07:09 PM
imm really soory about my english never went to school much left very young to go vietnam but ill try harder to be right .thanks about the rubber gasket on the p v c valve ill look at it i love this web sight & hope i dont get kicked off for being dumb maybe i could help someone . i have put on a belt a altenator a water pump a belt tentioner in last two days thanke again buffalo
Old 08-19-2006, 07:14 PM
maxwedge maxwedge is offline
A990 racer
Thumbs up Re: 98 buick squealing
This is not personal, but when technical issues such as yours are posted, it is difficult for us on the forum to sort out the info to give you accurate advice, so a clear and concise description is required. By the way we all are grateful for your call to aid this country.
Old 08-19-2006, 07:46 PM
AF -Advisor
I just looked at my pvc valve. There is a small o-ring on the bottom part of the pvc. It's about 1/2 inch up from the bottom of the pvc when I lift it out.
Old 08-20-2006, 10:48 AM
BNaylor's Avatar
No problem. Just do the best you can. No one is going to kick you off AF.
Thanks for the service to your country. Alot of us are in the same boat and Veterans of the Vietnam era.
Checkout the tech link below for PCV on a SII 3800:
http://macgp.clubgp.com/howto/engine/pcv/gt/pcv.html
In addition to the black o-ring on the PCV valve make sure you have the big orange one that seals the MAP sensor holder to the UIM. If that is missing it gives off a loud motorboat type sound.
Timeslip 08/12/06
Old 08-25-2006, 06:54 AM
Well i found my squelling noise .The p v c valve wasent in my new plenum so i been driving without one The grage who put it on should have seen that & also KEN CO should have told u it dident have a p v c valve. Thankes to the person who showed me where my p v c valve was. BY the way its to the end of the plenum u take off the wire hook up push down on the top of plastic thing then turn it & top comes off its under that u must take pair plires to pull it out it has a spring holding it down plus a o ring thanks guys buffalo
Old 08-26-2006, 12:25 PM
Some one tell me what the thing is i thought was my p v c valve. Its in the back of the plenum about in the middle it goes into the plenum & a hose goes to power brake boster then a littler hose goes to the left both hoses go on this plastic thing i would like know what it is . Also how could i have lost a qt of oil by driving with out a p v c valve . I lost a qt of oil in 200 miles . My car doesnt use oil . Hope i never tore up the engine . buffalo
Old 08-26-2006, 12:49 PM
BNaylor's Avatar
The plastic Y piece is a one way vacuum check valve.
It is quite conceivable to go through that much oil without a PCV valve installed. Due to improper crankcase ventilation the oil was probably blowing by the piston rings and valve guide seals. It will probably all burn out or just use some top engine cleaner like the one from GM or Seafoam. Just keep an eye out for any further oil consumption just to be safe. Good luck.
Timeslip 08/12/06
