Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-19-2006, 05:54 AM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
97 CV performance question
What can i do for under 200 bucks to add some pep under the hood? Everything is stock and it runs pretty good, but if it had more power i would like it a lot more. Its a great car. I cant blow a lot of money on it but would like it to be a little stronger.
Old 08-19-2006, 10:57 AM
amo4387622 amo4387622 is offline
Re: 97 CV performance question
The first thing I would do is go dual exhaust.
Old 08-19-2006, 10:58 AM
G-man422's Avatar
G-man422 G-man422 is offline
air intake, exaust.
Old 08-19-2006, 11:39 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Chip it.
MT
MT
Old 09-22-2006, 02:56 PM
Dondo's Avatar
Dondo Dondo is offline
For under $200. you can detail the car !!! But thats about it,, the best bang for the buck is change the rear gears to either 3:27, or 3:55 gears,,, that if you have 2:73 in the rear now ! Next would be duel exhaust,,, thats worth 10 hp,, over single exhaust.. or a MM air box and maf, with a re-program to your computer from " Angry Duck Tofo racing " Contact Chris for that,,, but that will run about $600. + Theres lots of things you can do,,, but it all takes money ,,, and the bad part is,, most of it is more then $200.oo
Going Where Others Fear To Tread
http://s46.photobucket.com/albums/f137/dondo5853/
Old 09-22-2006, 03:01 PM
Dondo's Avatar
Wink Re: 97 CV performance question
this is the web site you want to go to,,,,
http://www.adtr.net/ or www.Crownvic.net
Old 09-22-2006, 06:56 PM
reekor reekor is offline
You can full your tank with super unleaded gas.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 09-22-2006, 07:12 PM
Dondo's Avatar
Thumbs down Re: 97 CV performance question
The CV is setup to run on regular gas,, it does more harm then good to run high test in it all the time,, the timing isn't setup for 93 oct,, so if it can't brun it fully,, it will end up clogging EGR passages !! If you want to get more power out of 93 oct gas,,, have your computer reflashed to burn that,,, which will take changing the timing also..
Old 09-23-2006, 06:41 AM
Or you can save yourself all of that and pull the Octane Adjust Plug.
