94 contential executive
Oil light indicator sometimes comes on for a few minutes, DCL and speed dometer periodically goes out. Any one help with that? Also I want to purchase a remote control starter for my car but I need it to turn the car off also is there one that does both? My ignition is broke and instead of buying a new steering column I was told that I could buy that. Please help.
Re: 94 contential executive
Someone's pulling your leg. If your IGN switch is broken it can be replaced without replacing the steering column.
Remote starters can be programmed to run the engine for a period of time, then quit. I suppose one can be customized (electronically) to shut down manually however, when you have your IGN switch replaced this becomes moot. Electronic enomolies are usually traced back to a failing charging system. have your charging system thoroughly checked first. After that, the cluster may have to be removed, and the ribbon cable contacts cleaned.
-Steven 1996 Town Car, Cartier |
