Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 08-18-2006, 09:15 PM
princezzz_whatever princezzz_whatever is offline
Question 93 tracker oil pan removal HELP
I am trying to removal the oil pan and got 2 bolts that won't budge Need to replace after plug wasnt tightened properly and fell out loosing all oil bringing the oil lght on and directly after engine stalled got engine unseized but thinking bent a rod and am trying to fig this out since there is now an obvious clicking but having a serious problem with oil pan HELP PLS
Old 08-20-2006, 08:14 AM
viperh viperh is offline
Send a message via AIM to viperh Send a message via Yahoo to viperh
Re: 93 tracker oil pan removal HELP
Try tightening them to break them loose (You tighten untill it moves it usually pops). Once is pops you'll be able to loosen them easily. Also spray the bolts with liquid wrench or PB Blaster (comes in a can like wd40). If all else fails put a pipe over your wrench handle so you can get leverage, But go slow so you don't break the bolts.
