Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 08-18-2006, 04:24 PM
betsyr2 betsyr2 is offline
how to replace crankshaft sensor.
My 1997 quad 4cl car For months, has been dying periodically when running at 20-40mph, not setting any codes, it immediately restarts when I shift to N & crank. I replaced Idle air control valve myself & it seemed better, my gas miliage imporved greatly but dying not solved and much worse at high elevation when I took it out to Colorado. Finally when it died yesterday it set code P0335 Crankshaft Position Sensor Circuit.
  • Can a bad CPS cause car to die?
  • I can change oil, plugs, hoses, wire stereos, do other minor things, etc... is this something terribly diffcult to replace?
  • What's it look like & where is it? My Haynes Manual indicates the bottom of DIS (which I don;t know what that is) assembly but it often is misleading because it covers so many cars, engines.
  • Pep Boys says that the part is avail for like $30, so I'd like to try myself if poss & see if this fixes.
Old 09-08-2006, 01:45 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: how to replace crankshaft sensor.
This is an older post, but in case you're still watching it (or someone else with a similar question views it), here is a link to the AC-Delco website picture of the part (#213-970)
http://198.208.187.182/internet/View...Number=213-970
It is located in the front/center of the engine block, near the starter.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
