Old 08-18-2006, 04:22 PM
keithndi keithndi is offline
Removing rear door panel on '04
I popped off all of the plastic tabs, but not sure how to remove door handle. Is this holding the panel on?
Old 08-18-2006, 09:07 PM
hoezaycuervo hoezaycuervo is offline
Re: Removing rear door panel on '04
To remove the rear door panels, pry up the window switch on the front and back with a screwdriver. You will need to push in the metal clips that hold it in and it will out. Then in the door handle you need to pop out the little plastic cover and there are 2 bolts underneath that to be removed. Also pop off the cover around the lever to open the door. Then, work your way around the panel, popping the plactic clips that hold the panel on. Once these are removed panel will slip right off.
