Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-18-2006, 02:20 PM
OldsBuickGuy82 OldsBuickGuy82 is offline
Nearly cuts out...1992 CV
When I apply the accelerator just a little bit, while driving or in PARK, the car stumbles and nearly cuts off unless I stop giving it gas. Sometimes the engin will race over fast while at idle too and then cut down again. The check engin light goes a bit nuts when I start up then it just stays on. Starting is fine, no trouble there.
Advice/Ideas?
Thanks
Old 08-18-2006, 06:28 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Nearly cuts out...1992 CV
Possibly the throttle positioning sensor. If you have an analog voltmeter, you can check it fairly easily. One wire will have approximately 5 volts, one will have 0 volts(ground) and one will have a varying voltage. Check the variable voltage while SLOWLY working the throttle to wide open. The voltage should steadily increase. If the sensor is dropping out, voltage will drop instead of constantly rising. It should start from about .6 or .7 volt and climb to 4.5 volt or hightr.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-19-2006, 06:04 AM
reekor reekor is offline
Your check engine light is trying to tell you something, you might want to see just what that is. Doing a KOER test wouldn't hurt at this point.
Advice/Ideas?
Thanks
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 08-19-2006, 10:25 AM
And how does one do a KOER test? I've never heard of that before, what's involved?
Old 08-19-2006, 05:22 PM
way2old's Avatar
TOKEN HILLBILLY
Ford uses KOEO = Key On Engine Off and KOER = Key On Engine Running. They are different ways to access codes.
See if you can make any sense of this.
Old 08-19-2006, 07:12 PM
I can't! Maybe a bit of a breakdown?...I'd like to know how to do this.
Old 08-19-2006, 09:57 PM
Your best bet is to use a scan tool, this will put the car into test mode for you. Try this link
http://fordfuelinjection.com/files/s...koer%20ford%22
Old 08-20-2006, 03:13 PM
I figured it out after a little while, and the code I got was...
157 - Mass Air Flow signal is/was low or grounded - MAF.
I unplugged the MAF and the car runs perfectly now and has a nice increase in power. Is it ok to run with the MAF unplugged until I get one, will it do anything to hurt?...I notice the CEL is on now all the time.
Old 08-20-2006, 06:40 PM
way2old's Avatar
TOKEN HILLBILLY
You can get some electrical contact cleaner and try to clean the MAF wires. Just spray on the wires and do not use anything to wipe them with. Let it air dry and install to see if it is any better. Use a cleaner that does not leave a residue. All you are going to do if you run it unplugged is use a little more fuel. The PCM is placed in a default mode with the sensor disables.
Old 08-20-2006, 10:01 PM
I will try that. To clean the MAF should I remove those tamper proof screws and pull the sensor out of its housing, or just spray through the pipe without removing it?...I read that you can do it through the pipe. If it does require cleaning, should I be able to tell just via eye inspection?
Also, how much extra fuel are we talkin'?....
Thanks
Old 08-21-2006, 06:35 AM
way2old's Avatar
TOKEN HILLBILLY
You can clean it either way. If you remove it, you can make sure you get all the dirt off of it. Fuel should be in the 2 to 3 mpg range.
Old 08-21-2006, 12:57 PM
Ok, thanks for the advice
Cheers
