Old 08-18-2006, 02:19 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
ugh... broke a bolt, give me help
So I'm taking off my EGR... exhaust side bolt is rusty, so i soak it down with PB and work on the intake side. I get that on and all, and go back to the ex side. Still wont budge, soaked it with more PB... waited a few and tried again... and snapped the mother f'in bolt. So now I have an egr valve with a tube witting int he exhaust (not held on by anything) and the intake side open... and an exhaust manifold that has a bolt stuck in it that prevents me from gettign the blockoff plate on, and will probably blow the tube out of it once i run the car leading to a massive exhaust leak.
What is the quickest/cheapest/easiest solution here???
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 08-18-2006, 02:25 PM
poormillionaire2 poormillionaire2 is offline
Re: ugh... broke a bolt, give me help
You may have to take the exhaust manifold off and have it tapped and re-drilled. And then get a new bolt from napa or somewhere. I snapped my EGR bolt off in my manifold, but luckily I don't need either of those with the new headers, so I got off easy.
Old 08-18-2006, 02:33 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
That, or weld the blockoff on
Old 08-18-2006, 05:29 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Three option. 1. Weld like Wright said, 2. Drill out, tap and rethread. 3. buy a bolt out kit (although this might not work if it in there as good as you say)
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-18-2006, 08:59 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
use an "easy out"
Old 08-18-2006, 10:56 PM
capriceowns capriceowns is offline
Just rent a oxygen and acteline(sp) torch, and heat up the cast iron around the broken bolt, then put vice grips on it and twist it out.
cast iron will expand more then steel
That is if its cast iron.
just my
Old 08-18-2006, 10:58 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
I did the same exact thing... my solution... I bought headers....
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 08-19-2006, 02:08 AM
dont have th emoney for headers right now... and as for welding, the plate is aluminum and the mani is cast iron, wouldnt that be a bitch and a half?
It's pretty much snapped off flush... looks liek im gonna try an easy out and then if not drill and tap.
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 08-19-2006, 02:20 AM
goldz28's Avatar
goldz28 goldz28 is offline
Sometimes the way that appears to be the easiest is not really. If it does not work you will be stuck doing the drill and tap anyway. Anyway I would just do it right and not take an easy way out...
Good luck man
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 08-19-2006, 10:04 PM
bitch is TIG'd on
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 08-19-2006, 11:58 PM
goldz28's Avatar
bitch is TIG'd on
That would explain why the damn thing would not come off. Did you get it off yet?
Old 08-20-2006, 12:03 AM
I think that is how he fixed it.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 08-20-2006, 02:05 AM
Genopsyde's Avatar
The President
huh?
Old 08-21-2006, 01:30 PM
MIG'd rather... and that was the fix, welded it on
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 08-21-2006, 02:14 PM
Elk's Avatar
Elk Elk is offline
Not that it maters at this point, but I always heat stuff up for 3 or more minutes with a propane torch before trying to unbolt anything on an exhaust system.
Buick Park Avenue, 1997
