Old 08-18-2006, 08:58 AM
sausage sausage is offline
Interesting ways to display full-view clear models?
Like the Tamiya 911GT1 or F50.
I think even with some polishing they'd still look rather translucent rather than transparent. Is there any unusual way to display them?
I saw one previously which was half clear and half carbon-fibered.
Recent stuff:
Singapore scale modeling site at http://machinemess.singaporeanimenews.net
Old 08-18-2006, 09:39 AM
CeeElle's Avatar
CeeElle CeeElle is offline
Re: Interesting ways to display full-view clear models?
i'm just finishing up a clear-view Williams FW24. i painted half the body laterally so the left side is painted and decaled and the right is clear. it didn't work out as well as i'd hoped, but it's my first kit in about 25 years.
if i had it to do over, i would have left the whole thing clear.
Old 08-18-2006, 10:48 AM
cfcrules's Avatar
cfcrules cfcrules is offline
I saw one where the bloke had sprayed the ferrari clear red from the inside to give it shine. It would have been cool, but the paint built up in the corners and so ruined it in my opinion.
Old 08-21-2006, 02:34 PM
jdmaccordian's Avatar
jdmaccordian jdmaccordian is offline
Send a message via AIM to jdmaccordian
I did a Tamiya F50. I sprayed the front 25% of the car (front bumper, tip of hood and fenders) in yellow and faded it out into the clear body. I did spray on the inside and the inside molding of the body was weird and it didn't look good. If I had a chance to redo it, I would spray it the same but from the outside. I think it would look really nice.
djMS
Old 08-21-2006, 05:22 PM
Guiddy's Avatar
Guiddy Guiddy is offline
I'd spray parts of it but leave sections clear in a 'see through' style.
But have never tried this and wouldn't bother anyway!
Old 08-21-2006, 06:19 PM
Jay! Jay! is offline
Horizontally Opposed
Pin it to the underside of a piece of glass or clear plastic, with the proper colored version on top. Like sitting on a magic mirror.
Hierarchy of Subaru:
(Click to see mine!)
Old 08-21-2006, 09:11 PM
Gamerxz's Avatar
Gamerxz Gamerxz is offline
Heres a picture of my clear view ferrari f1 kit which i did.. its half painted half clear. Hope this helps
Old 08-22-2006, 12:43 AM
SeaBee SeaBee is offline
Gamerxz, that's a very nice one! I was actually leaning towards something similar if and when I get around to my next clear model (have 3 in the cupboard.
The one I did was like mentioned above - a 911GT1, with white faded out. Done from the outside. Came out nicely enough imo.
Old 08-22-2006, 08:21 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Personally, I think what Gamerxz has done is the very best way to build these kits. If they are built leaving the bodies clear, they will always look like plastic models- there are too many mold marks on the bodyparts and chassis parts for them to look like anyting else. But if you carefully plan clear 'cutaway' sections and paint the rest of the body the results can be spectacular. 'Feathering' or fading the edges of the paint can be very difficult to do well- I would just use a hard masked edge. But I would be tempted to overlap some CF decals on the inside by a few mm around the cutaway areas. All of Tamiya's clearview kits are of cars with CF body panels, so some CF around the edges would make them look even ome 'cut away'.
PHOTOBUCKET SUCKS
Old 08-22-2006, 09:55 AM
klutz_100's Avatar
Andy, would you CF the putside of the body and then paint over that?
Or are you thinking of placing CF on the "other/inside" side of the clear plastic? If so, how would you attach the CF to the body so that the pattern is facing "out"?
I've been toying with this thought since you first mentioned it some time ago and I have to admit I failed to come up with a good soloution
Old 08-22-2006, 01:17 PM
MPWR's Avatar
Apply the CF facedown (upside down) on the inside of the bodyshell plastic. It will look like it is applied correctly (rightside up) when viewed through the plastic- except it will of course be being seen through the plastic, instead of sitting atop it.
PHOTOBUCKET SUCKS
Old 08-22-2006, 01:37 PM
wouter1981 wouter1981 is offline
always paint those clear parts on the outside... I've played a while with the same car like gamerxz and painted it partiatly on the inside and it was horrible, made me throw the entire kit away ;-)
Old 08-22-2006, 08:36 PM
klutz_100's Avatar
I worked that bit out on my own What I couldn't figure out is how to fix the CF to the body so that it lays tight to the plastic
I guess you can't remove the decal from the backing paper so it willbe quite thick and stiff and you can't put any adhesive on the decal itself? Scotch tape it to the body behind the paint, maybe? But then how tight would it lay to the plastic on curved surfaces?
I like the idea and I'd love to see it done to see how it works. Unfortunately, I don't have a clear body kit to experiment with
