Old 08-18-2006, 07:28 AM
ColoradoSilverado ColoradoSilverado is offline
which diff do i have ?
How do i id my rear differential ?
It's a 2000 5.3 Z71
Bert
Old 08-18-2006, 08:44 AM
guumbah's Avatar
guumbah guumbah is offline
Re: which diff do i have ?
Should be a sticker in the glove compartment with codes for a bunch of stuff. Can't remember which specific ones refer to the diff (or if they were labelled). If you can't figure it out, post back, and I'll check mine at lunch.
2002 5.3l - Quadrasteer
lose (lüz): v - to suffer deprivation of : part with especially in an unforeseen or accidental manner
loose (lüs): adj - not rigidly fastened or securely attached
Old 08-18-2006, 09:09 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Probably the G80 (GM's GovLock) which is a limited slip unit.
In the glvoebox it will have the code G80 if you have this.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-19-2006, 12:29 PM
dlstewart01 dlstewart01 is offline
The G80 used in trucks today is a locker. It automatically locks when one rear wheel spins a certain % faster than the other. It will only stay locked 20 miles an hour and under. When the G80 is not locked it functions as an OPEN diff. It is NOTa limited slip. Check this out at WWW.traction.eaton.com/prod2.htm
Have a great day,
Don
Old 08-20-2006, 09:24 PM
guumbah's Avatar
In the Quadrasteer at least, the G80 is both. Mine chattered until I put in the limited-slip additive. Check any Quadrasteer forum, and you'll find numerous posts about getting the right fluid from the dealer.
Old 08-24-2006, 06:37 AM
What I meant was, do I have 3:42 , 3:73 or 4:10 ?
Bert
Old 08-24-2006, 08:57 AM
guumbah's Avatar
Same place - glovebox sticker. I know GT4 is 3.73 (what I have), I think GT5 is 4.10, not sure what 3.42 is.
Old 09-07-2006, 05:35 PM
bobboinge bobboinge is offline
I have a question about this. Mine says GT4...Is this a limited slip and when I change the fluid should I add a tube of friction stuff? I can feel chatter when making a slow turn.
Old 09-07-2006, 07:14 PM
Blue Bowtie's Avatar
Registered Offender
Friction modifier (GM Spec No. 1025358) is NOT required for centrifugal locker type limited slip differential axles.
Old 09-07-2006, 07:20 PM
Thanks Blue Bowtie; I guess I have a limited slip diff. I'll just change the 75-90 syn oil and call it a day.
Old 09-09-2006, 02:11 PM
tbuckit1's Avatar
tbuckit1 tbuckit1 is offline
Send a message via AIM to tbuckit1
3.73 is standard equipment on Z71s which is code GT4.
GT5 4.10
GT7 3.33
GT8 4.10
GU2 2.73
GU4 3.08
GU5 3.23
GU6 3.42
GV2 5.83
HC4 4.56
HF8 4.88
Most likely you've got the GT4, but you could also have a GT5
"What in the wide, wide world of sports is a go'in on here?" - Taggert
Old 09-10-2006, 12:14 AM
skipr skipr is offline
My 2005 only had two choices in ratio option 3:42 or 4:10.
