Still Not clear on THEFTLOCK
I have a 2K Montana. As usual, one or more of the RADIO lamps are blown. I am an electrician, so I am fairly comfortable with wiring and electronics.....but I am worried about unplugging the harness and having the Theftlock activated.
Should I be worried? Otherwise, I would just leave everything plugged in and do the lamp swap with connections still plugged in. It is the original CD/AM/FM system, so what do you think will happen? |
Re: Still Not clear on THEFTLOCK
Here are the instructions for my 2000 Oldsmobile. It is probably the same radio you have. Theft-Deterrent Feature THEFTLOCK is designed to discourage theft of your radio. It works by using a secret code to disable all radio functions whenever battery power is removed. The THEFTLOCK feature for the radio may be used or ignored. If ignored, the system plays normally and the radio is not protected by the feature. If THEFTLOCK is activated, your radio will not operate if stolen. When THEFTLOCK is activated, the radio will display LOC to indicate a locked condition anytime battery power is removed. If your battery loses power for any reason, you must unlock the radio with the secret code before it will operate. Activating the Theft -Deterrent Feature The instructions which follow explain how to enter your secret code to activate the THEFTLOCK system. It is recommended that you read through all nine steps before starting the procedure. If you allow more than 15 seconds to elapse between any steps, the radio automatically reverts to time and you must start the procedure over at Step 4. 1. Write down any three or four -digit number from 000 to 1999 and keep it in a safe place separate from the vehicle. 2. Turn the ignition to ACCESSORY or RUN. 3. Turn the radio off. 4. Press the 1 and 4 buttons together. Hold them down until --- shows on the display. Next you will use the secret code number which you have written down. 5. Press MN and 000 will appear on the display. 6. Press MN again to make the last two digits agree with your code. 7. Press HR to make the first one or two digits agree with your code. 8. Press AM-FM after you have confirmed that the code matches the secret code you have written down. The display will show REP to let you know that you need to repeat Steps 5 through 7 to confirm your secret code. 9. Press AM-FM and this time the display will show SEC to let you know that your radio is secure. 3-19 Unlocking the Theft -Deterrent Feature After a Power Loss Enter your secret code as follows; pause no more than 15 seconds between steps: 1. Turn the ignition on. LOC will appear on the display. 2. Press MN and 000 will appear on the display. 3. Press MN again to make the last two digits agree with your code. 4. Press HR to make the first one or two digits agree with your code. 5. Press AM -FM after you have confirmed that the code matches the secret code you have written down. The display will show SEC, indicating the radio is now operable and secure. If you enter the wrong code eight times, INOP will appear on the display. You will have to wait an hour with the ignition on before you can try again. When you try again, you will only have three chances to enter the correct code before INOP appears. If you lose or forget your code, contact your dealer. Disabling the Theft -Deterrent Feature Enter your secret code as follows; pause no more than 15 seconds between steps: 1. Turn the ignition to ACCESSORY or RUN. 2. Turn the radio off. 3. Press the 1 and 4 buttons together. Hold them down until SEC shows on the display. 4. Press MN and 000 will appear on the display. 5. Press MN again to make the last two digits agree with your code. 6. Press HR to make the first one or two digits agree with your code. 7. Press AM FM after you have confirmed that the code matches the secret code you have written down. The display will show ---, indicating that the radio is no longer secured. If the code entered is incorrect, SEC will appear on the display. The radio will remain secured until the correct code is entered. When battery power is removed and later applied to a secured radio, the radio won’t turn on and LOC will appear on the display. As you can see, if the theft deterrent has been activated and power is removed from the radio then it locks itself until the code is entered. If the theft deterrent was not active then removing the power will have no effect. Hope this helps. |
i have a 2000 montana and the radio is set with the vin # . when you reinstall the radio it will work. i had to replace my battery and when i started the cvan all i had to do to the radio was set the time and the radio stations
