Old 08-17-2006, 09:38 PM
chubbygoatboy chubbygoatboy is offline
Blower motor on 99 Cavalier, only works on the 2 high speeds??? WHY??
Does anybody know how to diagnose a 99 Cavalier blower motor problem? The first two low speeds do not work but the 2 higher speeds do. I pulled the motor thinking it might be it, but it only has one hot and one ground wire. So are the speeds controlled by the resistor board mounted in the blower housing, or the fan switch? One other thing, while I had the motor out, I disconnected the resistor board, and turned the switch on holding the fan tightly in my hand, and it then only had high speed. Does that tell me anything?? Any help is greatly appreciated!! THANKS
Old 08-17-2006, 10:29 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Blower motor on 99 Cavalier, only works on the 2 high speeds??? WHY??
blower motor resistor, its a common problem
this thread will help
http://www.automotiveforums.com/vbul...d.php?t=568983
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 08-18-2006, 10:41 AM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
is it just me or does it seem like ALOT of cavys have problems with the AC???
Old 08-18-2006, 11:19 AM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
alot of cavays have problems in general lol
Old 08-18-2006, 12:29 PM
Thanks for the help. I am stopping at the dealer tonight to get the board. I will repost my conclusion to confirm. THANKS
Old 08-18-2006, 02:43 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Oh yeah I forgot I have this problem too, first 2 lows don't work. So it's definitly the resistor?
Old 08-18-2006, 03:56 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If you want to be a 100 percent sure you can test at resister block with test light. Bit a Calalier and a bad blower mt. resister go together.
MT
MT
Old 08-18-2006, 07:34 PM
Well it definitely was the resistor board, ( about $30 dealer), in the blower housing, behind the blower motor. It was corroded and blown. I pulled the three 5.5 mm screws out that hold the blower in. Then pulled out the two screws that hold in the board. Really a pretty easy job as long as you have a 1/4" hand driver with a swivel and the 5.5 socket. It only took about 20 minutes of being contorted in the passenger floor board!!
THANKS for the help!!
Old 08-18-2006, 08:30 PM
Banned
yes and those 20 min suck when your tall
Old 08-19-2006, 01:22 AM
Lances133's Avatar
Great...another project...ehh oh well, my a/c doesn't work anyway and the cold weather is coming up soon so i'll mostly be using the higher ones anyway...f*ck it.
Old 08-19-2006, 06:53 AM
Banned
yea check your ac though, my ac started messing up so i gave up worying about it, ended up being two loose bols (which would of been adn easy fix) but sice i didn't check it out ended up busting both bolts that hold the compressor to the block, that sucked, waiting for a belt to come in as your car is in an unsecured public parking lot, the only thing i have to say about that is thank god for a comerical acct, with the parts store, damn ac bypass belts would of taken 4 days to get in without it
Old 08-19-2006, 09:34 AM
MT-2500's Avatar
AF - Advisor
Glad you got it fixed.
One thing to remeber is if it keep on blowing it a bad fan blower will pop them things.
Always check the amp draw on fan motor.
MT
MT
