Old 08-17-2006, 04:25 PM
markwb's Avatar
markwb markwb is offline
Wind Noise
When up at highway speeds (65-70 mph) I hear a faint, but noticeable wind noise coming from the area at the "A" column where the driver door seals to the body. Any suggestions, or has anyone had a similar problem that may want to share some info. TIA
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 08-17-2006, 09:49 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: Wind Noise
If the weatherstripping looks good, then try to adjust the door striker on the body in a little to tighten the door. If that does not help, then I can let you in on a little secret.................
If all else fails trying to stop windnoise on a door to body seal (Not a glass seal) then roll the window all the way down. Place your knee on the door panel towards the area of the noise. Grab hold of the upper part of the door and slowly, but firmly, pull the top of the door towards you while holding the lower part of the door with your knee. This will actually bent the upper part of the door inwards to give a closer fit.
Old 08-18-2006, 04:44 AM
markwb's Avatar
Re: Wind Noise
Thanks for the input, Johnny. I'll try those suggestions as soon as I get the time.
Mark
