Old 08-17-2006, 03:38 PM
kutlass70 kutlass70 is offline
2000 blazer starting problems
I have 2000 S-10 blazer. It starts real rough. Sometimes it takes a couple of sec. to start. I put a new fuel pump and injector cleaner in. It started rite up. After about 3 days it was back to same problem. It doesn't do it all the time. If it runs for a while turn it off and then it starts rite up with no problems. I was wondering if it was a fuel problem or something else. Thanks
Old 08-17-2006, 04:44 PM
Blazer SS Blazer SS is offline
Re: 2000 blazer starting problems
New fuel filter? And did you check the fuel in the tank? Check for carbon tracks at the coil. Just wipe between the coil and the heat sink.
Old 08-17-2006, 08:11 PM
my bad i put a new fuel filter in not a fuel pump. I will check tommorrow on the carbon. thanks for the reply
Old 08-17-2006, 08:48 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Any check engine lights?
Also, what was the brand name of the fuel pump?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-18-2006, 09:21 AM
no check engine lights and I haven't put a new fuel pump on. I just replaced the fuel filter.
Old 08-18-2006, 12:52 PM
BlazerLT's Avatar
AF -Advisor
lol, ok, best you don't say you put a fuel filter in when you post.
Have your fuel pressure checked.
Old 08-18-2006, 04:35 PM
lol sorry about the fuel pump fuel filtler issue. Thanks i will check fuel preasure.
Old 08-18-2006, 06:47 PM
I checked fuel preasure. It was 62psi without turning over and after a second it went back to 0. When I started it up it idled at 54psi.
Old 08-19-2006, 01:10 AM
BlazerLT's Avatar
AF -Advisor
fuel pressure regulator leaking or the check valve in the fuel pump assembly isn't seating.
Old 08-20-2006, 12:12 AM
okay thanks will check. hoping for regulator. fuel pump check valve would mean dropping fuel tank.
Old 08-31-2006, 09:06 AM
alblogg's Avatar
alblogg alblogg is offline
Same prob I had with my '99 untill that one day the day after I had filled the tank with gas it did not start and I had to drop the tank and replace the fuel pump.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
